RogHodge wrote:What if I take the roll, and create two - two strand (maybe three?) cables? So two pair of 14gage wires in parallel? Essentially doubling the capacity of the 14gage wire. The description would like to tout the 14 as having 17a capacity, seems a touch optimistic. But if I tripled it that should give me a 30amp capacity easily, right?
rowerwet wrote:if you can't find the exact gauge wire you need or don't want to pay through the nose for it, run two smaller wires that add up to more than the gauge you need, they do this on airplanes all the time. I don't know if it is for redundancy, weight, or just to allow more flexibility, but almost every airplane I work on has it, especially in the battery and starting circuits.
At the voltages and ampacity needed here, use of the correct gauge or even slightly larger to satisfy the circuit requirements isn't critical (weight vs ampacity). Go small for LEDs, larger for 12v appliances or inverters, larger still for charging circuits. Protect everything with cut-off switches, circuit breakers, and fuses. Redundant wiring isn't needed, unless you plan to fly it! However, 110vac is a little more critical than 12vdc; try to match or oversize your wiring to the loads expected. Of course, breakers and/or fuses will be needed. Proper boxes and connectors to meet code as well, if you ever intend to sell "legally".International Telecommunication Union wrote:Aircraft wiring typically features twice or triple redundancy.
H.A. wrote:Its just an excersise in extra work and a monument to wanker build practices.
