What's next?
What's next?
Postby sunny16 » Mon May 01, 2006 9:55 am
I am in the process of skinning my trailer right now. My question is what do I need to do before I fill all the screw holes and staple holes with bondo? Do I need to spray the exterior with spar varnish first to seal it all and then bondo or bondo first and then spray it? I didn't seal the insulated pockets between the skins. Didn't think it would serve any purpose. I think I will finish it with a couple coats of paint. Don't want to do the aluminum thing. Maybe later. What have any of you done??? :roll:
I cut it three times and it's still too short!!
Perfection is all I ask.......
sunny16
Images: 70
Postby halfdome, Danny » Mon May 01, 2006 11:17 am
Bondo the raw wood is what I would do. :D Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby madjack » Mon May 01, 2006 11:45 am
halfdome, Danny wrote:Bondo the raw wood is what I would do. :D Danny
...yep, especially if painting instead of an exterior skin................................MJ 8)
Postby asianflava » Mon May 01, 2006 3:12 pm
I used epoxy and a lightweight filler. It is basically the same thing. You've caught up to me. I'm still trying to figure out how to get the aluminum home. I think I'll have to rent a U-haul.
asianflava
Postby sunny16 » Tue May 02, 2006 9:29 am
Thanks for the info. I knew you would respond, Madjack. I appreciate it!
sunny16
Images: 70
