The SunshineInn
Re: The SunshineInn
Postby prohandyman » Thu Feb 06, 2014 5:28 pm
Reworked a 1940's Oldsmobile license light and bracket for use on this. It was missing both the red lens and the clear license lens, so I crafted them from the lenses from a cheap plastic one on a throw away taillight. Also had to attach a new bulb socket.
116575. Of course it will mount on top the aluminum skin once installed.
Dan
prohandyman
Images: 785
Re: The SunshineInn
Postby be_a_jayhawk » Thu Feb 06, 2014 6:57 pm
I don't know where you find your parts but they look sweet!
be_a_jayhawk
Re: The SunshineInn
Postby prohandyman » Thu Feb 06, 2014 9:45 pm
I am a scrounger...I will walk thru an antique store or swap meet, pick up an item, and say to myself..."how can I use this thing in a camper or hotrod"! It's kinda like this light...114288
You have probably walked past many...they have round hooks on the back, and a long, 2wire cord, usually rotten. Usually metal, sometimes plastic or glass. they are "Head board lights".. People used to hang them on the headboard of their bed to read by. That's what the hooks were for. I just cut them off, install a new cord, screw in a 12 volt bulb and use them for camper lights. Not necessarily original equipment, but vintage looking. This ones got a pul chain off/on switch.
Dan
prohandyman
Images: 785
Re: The SunshineInn
Postby prohandyman » Thu Feb 06, 2014 9:59 pm
When I wanted an old luggage rack for the'46, I first looked for an old Volkswagen roof rack. Those are gold these days, so. I searched the inter web for pics. Soldered some plumbing fittings together, epoxied some oak dowel rods in, took an old skid and cut it up for the slats, and antiqued the whole thing for the "weathered" look. Of course the question always asked is " where did you get that old roof rack?"
103230
And have you ever been able to walk thru an old junk yard...it's getting a lot harder to do these days with everyone being "sue happy" but, when I can, and I happen to see the rare sight of an old camper sitting in the weeds, I make a beeline to it for scrounging parts. Most people walk right by them. I have only encountered 1 snake in all my walks...I try to go in the winter while most creatures of this nature are a little less inclined to see me as a threat!
Dan
prohandyman
Images: 785
Re: The SunshineInn
Postby prohandyman » Fri Feb 14, 2014 6:53 pm
Started puttin the roof on today116795
The front and back will be polished and a yellow "Chevron" type of pattern will be painted on the lower portion.
Dan
prohandyman
Images: 785
Re: The SunshineInn
Postby bdosborn » Fri Feb 14, 2014 9:42 pm
What kind of stain did you use to get that wonderful vintage finish on the birch?
Images: 806
Re: The SunshineInn
Postby prohandyman » Sat Feb 15, 2014 7:00 am
Ah ha...ancient Chinese secret...my mothers uncles cousin showed me this little trick once when he was repairing some water damage in an old camper...
2 parts boiled linseed oil, 1part oak wood stain, 1part paint thinner, dash of beeswax, heat in a pan on the stove while stirring and apply with a roller and back brush! Sand...repeat! And a partridge in a pear tree! Whew!
Then , I found an Amber tinted Shellac at a hardware store, tried a can, and bingo... A perfect match! I have had several compliments on the antique birch look it gives. Replaced a whole ceiling panel in a Vagabond once it and you could not tell which one I replaced.
I will check the can when I get in the shop today and get the brand. It dries quick, and is sand able.
Dan
prohandyman
Images: 785
Re: The SunshineInn
Postby bdosborn » Sat Feb 15, 2014 10:07 am
Thanks, BTW I like the Humphrey light too. Did you convert it to electric light?
Images: 806
Re: The SunshineInn
Postby prohandyman » Sat Feb 15, 2014 2:34 pm
Yes it was a challenge drilling out the tiny gas passage ways to allow a small wire but it worked. Epoxied a 12 volt bulb socket into the stem.
Dan
prohandyman
Images: 785
Re: The SunshineInn
Postby prohandyman » Wed Feb 19, 2014 6:00 pm
Taillights installed temporarily until polishing is done.
116939
Dan
prohandyman
Images: 785
Re: The SunshineInn
Postby prohandyman » Wed Feb 26, 2014 9:50 am
Front is polished. Used Nuvite polish... The best! From the window down will be painted yellow to match the sides.
117163
Dan
prohandyman
Images: 785
Re: The SunshineInn
Postby KCStudly » Wed Feb 26, 2014 10:27 am
prohandyman wrote:Front is polished.
... he said with a gleam in his eye.
Looks fantastic! :thumbsup:
Re: The SunshineInn
Postby prohandyman » Tue Mar 04, 2014 10:08 am
Potty closet finished
117385
Dan
prohandyman
Images: 785
Re: The SunshineInn
Postby prohandyman » Mon Mar 17, 2014 11:52 am
Sides going on.
117953
Dan
prohandyman
Images: 785
Re: The SunshineInn
Postby Verna » Mon Mar 17, 2014 3:27 pm
I just visited Dan's workshop and the Sunshine Inn is beautiful!!! He has a lot of well-thought out innovations that are really neat. Great job, Dan!!
Verna
Indianapolis, IN
Verna
Images: 49
Users browsing this forum: Google [Bot] and 9 guests
