This evening I was able to finish the wood template for my main cabin doors and cut the door skins from the leftover aluminum honeycomb that I also used for the floor. My template broke Sunday when I wasn't careful enough handling it so I had to make another one before I could cut the actual door skins
I decided to make my doors first before the interior walls as I figured the doors would drive the detailed measurements of the wall cutouts, and I still had some uncertainty in the door details (and risk of a costly mistake). Making these door skins get me past the most risky part of fitting my doors I think, or at least I feel more at ease now
Here are the 2 doors, the good template, and the top piece of my first (broken) template. I used a straight trimming router bit to follow the template clamped underneath the slightly over-sized pre-cut pieces of aluminum. They are 27" w by 40" high, with cutouts for 14"x24" windows. The construction plan is to sandwich these skins and 0.2" birch plywood for the interior, with 1/2" foam inside the sandwich along with plywood strips around the door edge for a solid trim mounting surface with a total thickness of 1-1/4" (or a few hundredths less). I'll use 1" T-molding around the door frames using the approach described in the DIY door construction thread
http://www.tnttt.com/viewtopic.php?f=21&t=54654
The aluminum sheets I had were "rejects" for aircraft use so they had SCRAP written on them with a big marker, so I picked areas with less to clean up while not wasting any of the overall sheets. These need some cleaning and polishing since there was no PVC film to protect it from scratches.
Here is the edge view - the edge will eventually be covered by the T-molding, but I may want to cover or fill with something first, perhaps epoxy. On the floor panels I just used aluminum tape but those edges are all protected inside the walls and aren't likely to be exposed like the door edge might.
I will probably wait on the final door construction until I have latches. I still need to pick out latches and am still deciding whether to use retro handles, recessed rectangular ones like I have for the smaller cooler/cargo doors, or something else. I'll use the same hinges I have for the small doors.
PS. By the way, the wheels in the background of the first picture are on Craigslist for sale. The white ones are the original wheels I got with the trailer frame with worn but useable tires, and the others are 2 of a set of 4 from a '97 Ford Explorer (I kept the best looking pair of rims and put on new tires, and the pair for sale has tires that are shot). They are 15" x 7" rims with a 5x4.5" bolt pattern.
