48Rob wrote:It looks like there is just a sleeve welded to the frame to carry the shackles.
Were it mine, I would use shackle hangers designed for the purpose, which will spread the load.
Is the spring hanger attached the same way? I would be real worried about all the attachment points on a trailer built like that, including the tongue...
You might consider building a "sub" frame, that is, weld the hangers to a suitable piece of angle and then weld or bolt it to the frame.
Rob
Rob-(A)Yes,it is just a 1/4" thick sleeve, just welded to the original frame tubing (with no further support or bracing)...look at the picture in extreme close-up, and you'll see how thin walled it is, and minor interior surface rust (it just pulled apart, not rusted thru). I think that all the hanger mounting points are similarly weak, and untrustworthy, even if I could patch that one back in place, I would never trust any again. I am primarily a "bolt-together" aficionado, having seen far more welds fail than bolts, and usually with more costly consequences (with one notable exception: a big-block Chevy connecting rod bolt @ 7800rpm...). I remember reading about the Liberty ships' welds breaking apart in WWII; I have never fully trusted welds since I read that (yet, I want to learn welding...go figure?). (B) The hanger welds were the only ones that I ever worried about; the others were just attaching angle to rectangular tubing, and were solid (and the new metal we welded on is done so even better, and of thicker-walled stock). The tongue is an entirely new piece, of thick-walled 3" square tube, welded to three crossmembers and to a second longitudinal center beam. Really burned in, and solid.48Rob wrote:(A)It looks like there is just a sleeve welded to the frame to carry the shackles.
Is the spring hanger attached the same way? (B)I would be real worried about all the attachment points on a trailer built like that, including the tongue...
(C) You might consider building a "sub" frame, that is, weld the hangers to a suitable piece of angle and then weld or bolt it to the frame.
Rob
48Rob-that's what I plan on doing, except the angle-up will be on the inside, where I can weld (and bolt, of course) without having my very fugly welds show (and without having to remove the fenders, which are in the way of the 36" long angle stock). I plan on using a 3 ft (the new springs will be 25.25" long) length of 1/4" angle (or 3/16" if it would be strong enough, I'll research) with weld/bolt brackets like shown by jss06 attached to the piece before final attachment to the trailer. My repairs will be hidden from view, since I just know the welds will be horrendous. So, out of sight and painted black.... But, I'm going to turn up the heat to really penetrate the steel, so it might just work out. My practice plug welds aren't too shabby, so I'll utilize them too. I've just now lifted the whole trailer up on four-cornered jackstands, and I'm using the tongue and Chevelle jacks, and my stabilizers to supply extra support as well. Here goes....48Rob wrote:I did a similar setup on a trailer awhile back.
It was a large angle, in the photo the end is not visible, but it fit in the space inside the fender.
I do have a question, though: for my 1515 lb (current loaded weight) or maybe 1600 lb trailer (after new axle, springs, reinforcement), would I be better off getting a 3500 lb axle (might as well get heavier-duty) with 1750-2000 lb springs, or get even heavier rated springs? And did I mention shock absorbers to come?
working on it wrote:... I'm going to turn up the heat to really penetrate the steel...
I've got another question (or two) for you Rob;
