OzarkRay wrote:I used a Kreg pocket screw kit for doing mine. Worked great, no visible holes when finished. I used poplar for the spars and they've held the screw heads perfectly. No splitting! I think the usual way of doing it is to have the head of the screw and the pocket hole in the spar, not your plywood wall. I don't think it would work out so well the other way. One thing I would recommend is that you use a clamp that will hold the spar in place while you're driving the screws. Since you're pushing at an angle when you're driving the screw you can move the spar out of alignment. I used a 6' long pipe clamp. They're pretty cheap to put together. Good luck!
