Stainless Steel Micro-Airstream behind motorcycle
Re: Stainless Steel Micro-Airstream behind motorcycle
Postby ST1100 » Wed Feb 12, 2014 3:25 pm
Hi Meelis - I saw your build and it's one of the finest homebuilts I've ever seen !
50 years camper and 35 years biker !
1977 Eriba Troll
2001 Honda GL1800 with trailer hitch, Ford Focus Pininfarina Convertible with hitch
ST1100
Images: 199
78: Stainless Steel Micro-Airstream behind motorcycle
Postby ST1100 » Mon Feb 17, 2014 4:16 pm
Well - last saturday I worked 12 hours in my garage !
After fixing the first sheet of the roof, I cut the front sheet and drilled all the holes and clamped it to the frame to drill thru the holes into the frame.
1977 Eriba Troll
ST1100
Images: 199
Postby ST1100 » Mon Feb 17, 2014 4:22 pm
I cut the sheet a bit too long to have a little tolerance and marked the correct length from the frame and then cut it precisely.
I drilled the rivet holes on my tabletop, then clamped the sheet again to the frame and drilled through it into the frame.
I noticed too late, that the upper line of holes had to be defined from the cornerpiece :shock:
But now it is too late.
1977 Eriba Troll
ST1100
Images: 199
Postby ST1100 » Mon Feb 17, 2014 4:30 pm
Thinking how to make the big door on the left side watertight, I decided in the evening, that there will be no big door.
That saves me weight and building time
I will take a big sheet and close the left side completely. Only a window will be there.
So I closed this side but took no pictures, because it was after midnight.
1977 Eriba Troll
ST1100
Images: 199
Postby xadmx » Mon Feb 17, 2014 5:31 pm
awesome build, looking very smart :thumbsup:
adam
xadmx
79: Stainless Steel Micro-Airstream behind motorcycle
Postby ST1100 » Sun Feb 23, 2014 5:08 pm
Best weather here in Southern Germany so I used it to spend my Saturday in the garage.
I closed the left sidewall with a big sheet 1440 x 1000 mm and drilled and deburred a lot of 4 mm holes.
Set all together and made a first rollout into the sun.
Then I cut another smaller sheet to enlarge the big sheet so I can close the rear part of the roof with the connected sheets.
1977 Eriba Troll
ST1100
Images: 199
80: Stainless Steel Micro-Airstream behind motorcycle
Postby ST1100 » Sun Feb 23, 2014 5:15 pm
Pure sunshine today, so my wife told me to ignore the waiting bathroom ceiling and sent me out to my trailer.
:lol:
Today I connected the sheets, attached it some times to the frame and cut another smaller sheet for the front part of the roof.
then the next fitting and drilling more holes ...
1977 Eriba Troll
ST1100
Images: 199
81: Stainless Steel Micro-Airstream behind motorcycle
Postby ST1100 » Sun Feb 23, 2014 5:24 pm
The frontal part of the roof will get a big clear plexiglas window, so I can see the stars before sleeping.
Into the rear part (above the tabletop) I will insert a transparent vent equipped with mosquito net.
Next step is to cut the left window into the big sheet and the cutout for the roof vent.
1977 Eriba Troll
ST1100
Images: 199
Postby jae » Tue Feb 25, 2014 5:15 pm
Very nice! This is exactly the type of build I've been hoping to find for inspiration on my own.
jae
82: Stainless Steel Micro-Airstream behind motorcycle
Postby ST1100 » Fri Feb 28, 2014 3:23 pm
Friday afternoon and sunshine.
I returned early from my office and entered my garage.
Removed the sheets from the frame after marking the right place for my vent and window.
Then drilled the holes for fixing the windows later with stainless screws and cut the holes for the window and the roof vent.
Then puzzled all together with polyurethane glue and shot my first line of rivets into the skin :D
Then supported the whole thing - so the glue will harden nearly like the sheet is bend later on the frame.
1977 Eriba Troll
ST1100
Images: 199
Re: 79: Stainless Steel Micro-Airstream behind motorcycle
Postby S. Heisley » Fri Feb 28, 2014 4:38 pm
ST1100 wrote:Best weather here in Southern Germany so I used it to spend my Saturday in the garage.
The good weather where you are located and an understanding wife allowed for some excellent progress on your build! :applause:
83: Stainless Steel Micro-Airstream behind motorcycle
Postby ST1100 » Sat Mar 01, 2014 2:16 pm
This morning after breakfast I reanimated my bike from hibernation.
From march 1st my bikes season plate is valid again and she got back her battery and started immediately.
:D
After a short round to test the brakes I went to the garage, took the wall, I pieced together yesterday and attached it to the trailer frame.
Then I hooked my raw trailer to the bike and made a test ride.
It follows fine without any problems and I tested it up to 100 km/h (60 mph) !
The mirrors of the bike are wider than the trailer (3.3ft) so I will not have any problems in the traffic,
and the fuel consumption will not rise very much, i hope.
1977 Eriba Troll
ST1100
Images: 199
Postby conn.rod » Sat Mar 01, 2014 7:40 pm
that is awesome dude
conn.rod
Postby S. Heisley » Sat Mar 01, 2014 7:46 pm
Good going! The two look fantastic together, too! :thumbsup: :applause:
Postby pchast » Sat Mar 01, 2014 9:35 pm
That's great. How's the trailer balance now that most of
the skin is on?
pchast
Images: 97
