your favorite REAL fire starting methods.
Re: your favorite REAL fire starting methods.
Postby Wolffarmer » Sat Mar 01, 2014 11:08 pm
Jiminsav wrote:I learned this from a great fire starter..pile up some wood..shove a road flair under it.. :R
I did that once when I camped with some good LDS people and nobody had matches. Lucky I had some road flares
Wolffarmer
Images: 309
Postby Junkboy999 » Sun Mar 02, 2014 12:47 am
I boy scouts, I use to use steel wool from the mess kit and a battery to start fires. I lights up like a filament of a light bulb for a quick second and starts your tender burning.
Junkboy999
Images: 52
Postby Redneck Teepee » Sun Mar 02, 2014 1:28 am
Works every time!
Redneck Teepee
Images: 21
Postby rowerwet » Sun Mar 02, 2014 6:51 am
we always camp with kerosene lanterns, we buy the citronela oil for them to keep bugs away, a twist of paper with lamp oil poured over it, wait a bit, light it. the oil starts without the big explosion gasoline will have, and burns hot enough to start even wet wood.
rowerwet
Images: 521
Postby KennethW » Sun Mar 02, 2014 7:06 am
newspaper and a propane self starting torch.
KennethW
Images: 82
Postby GerryS » Sun Mar 02, 2014 7:23 am
I start with pine needles or grasses that are dry neat me. If that's not available, I'll use 3 inches of natural jute twine. The progressively larger wood.
If I'm really desperate I'll move on to a small amount of lighter fluid and ferro rod. If things are really really bad, the ill consider big guns. Lighters. If you can't start a fire that way, learn, It will improve your experience camping in unexpected ways. There is something almost therapeutic about starting with a few scraps of stuff and ending with a fire that warms an area. I can't explain why or how, but there is a deep relationship between starting a fire and handling life's challenges...and fast solutions are rarely the right answer.
I ran into this guy a few years ago. He has two videos, one about his cabin then this one about fire. He's a bit of a philosopher, and I LOVE this one! He says what I'm trying to say a lot better, especially when I am using an iPad while getting ready for Mass...
http://youtu.be/XT8eWTXa00I
GerryS
Postby canned o minimum » Mon Mar 03, 2014 12:05 pm
I'm an "arborist" but never use tree branches or "conventional" firewood. ( Takes up too much room)
I use 2x4s that store nice and tight in a milk crate. I've found that one milk crate full of 2x4s will last most of the nite( till bed time) The wood can be split into varying sizes/thickness to regulate how fast the wood gits burned up.
I carry a hatchet at all times ( cutting tool AND hammer in one). I simply split the 2x4s into kindling and place newspaper( which I use fer reading also) under the "log cabin" style firewood pile.
The firewood is easily transported in the crates and very easily split to the desired pieced fer kindling/firewood.
I also almost always bring along a washing machine tub ( apartment size) to use as my fire pit. It is outfitted with 3 legs that are adjustible in height and this gives off great heat. The added bonus is that the tub is high enuff to put any smoke ABOVE yer head ( most of the time )
One match and the fire is started EVERY TIME.
The newspaper has many uses in the camp. I always read it fer relaxation. The advertisements git burned first. Then the sports page..then the classifieds...all in order of importance ( or the lack thereof) The cartoons are last to go.
Here in SoCal fires are a thing of the past fer wilderness campin so I never have a fire in the woods. Altho, if I was to have a fire there it would be the tee pee style with leaves or pine needles and pine pitch.
canned o minimum
Postby GerryS » Tue Mar 04, 2014 4:48 pm
I like the cartoon last part :)
Dimensional lumber doesn't burn well....too many pops and flying ash. that's too bad. I hate buying firewood too, and the restrictions thanks to disease and invasive pests make bringing from elsewhere a dangerous proposition.
GerryS
Postby lrrowe » Wed Mar 05, 2014 1:28 pm
Racquetman wrote:Hey Bob, thanks for the info. there's nothing wrong with easy, and I think a 2 or 5gal. container will last a long time for the price, looks like great stuff!
I was thinking the same thing. I like to experiment with new things. And I think it might be nice to have a small container just for the fun of it. But I can see myself making some of some of those homemade starters such as sawdust or shavings and melted wax and so on.
But like KennethW, I pretty much use a propane torch now and blush, I was taught differently when I was a Boy Scout. But at least it makes me "prepared."
Bob
lrrowe
Images: 439
Postby Racquetman » Wed Mar 05, 2014 4:36 pm
Yeah Bob, I think its a good idea to have more than one option depending on the situation, but the older I get, the more I like easy, even if it cost a little more......JMHO!
Racquetman
Postby CharlieL » Wed Mar 05, 2014 4:47 pm
Pile up small tiny twigs, then small twigs. THEN I put in the "Fatwood" , more small wood, then the bigger ones, fire up the small twigs, and make sure your "fatwwo" is burning. Never fails
(what is Fatwood you say? I usually find it right there in the woods by my house. It's just an old pine stump from a tree that died suddenly, then the roots send up sap. goes into the stump .)
I usually just go into the woods, find an old stump. give it a kick, if it's solid, probably fatwood.
Someday I will get off my rump and jump into a build, Thanks folks, for the info. and the things y'all do for one another
Charlie
CharlieL
Postby lrrowe » Wed Mar 05, 2014 4:55 pm
Racquetman wrote:Yeah Bob, I think its a good idea to have more than one option depending on the situation, but the older I get, the more I like easy, even if it cost a little more......JMHO!
Well then, who ever gets some of this stuff first, has to come back with a report.
bob
Bob
lrrowe
Images: 439
