Building the "Heart of Gold" - Done 3/9/2014
Re: Building the "Heart of Gold" - started!
Postby drewh1 » Mon Feb 24, 2014 5:58 pm
Inspired by Citylights "Cooler" project, I decided to take mine out of the garage for the first time. It tows well, don't really notice it breaking. It bangs around a bit on bumps. Do any of you have an idea how to quiet the slip in to hitch? I think that is what is making the noise.
I need to turn the hitch ball around to raise the front. I think it will be basically level then. It is really easy to back up and park, got it in the little bat cave garage, first try! This week, I'll finish the tongue box and hopefully the hatch, then I am going camping.
"If only I knew what I know now when I started . . ."
My Build Journal http://www.tnttt.com/viewtopic.php?f=50&t=56916
drewh1
Images: 7
Postby dano » Mon Feb 24, 2014 10:34 pm
Looks good. Lets go camping !!!!
[email protected]
Morgan Hill Ca.
dano
Postby PKCSPT » Tue Feb 25, 2014 2:53 am
Looks really nice.
121172 116946 159644
PKCSPT
Images: 61
Postby drewh1 » Wed Feb 26, 2014 1:10 am
thanks!
drewh1
Images: 7
Postby Transit80 » Wed Feb 26, 2014 2:43 am
Just one word describes this build and that is SUPERB!!!, going to pinch loads of ideas for mine :thumbsup: :thumbsup: .
Chris
WED BERRUM EXUM TAE
Transit80
Postby drewh1 » Wed Feb 26, 2014 12:09 pm
Thanks Chris - Pinch away, that is how I did it and that is the great thing about this forum. I'll look forward to seeing your build!
drew.
drewh1
Images: 7
Postby drewh1 » Thu Feb 27, 2014 7:38 pm
Not much time to work, but I did make some progress on the tongue box. It is turning out nice.
drewh1
Images: 7
Postby KCStudly » Thu Feb 27, 2014 10:22 pm
Postby bc toys » Fri Feb 28, 2014 7:07 am
you can get a pin that fits tight in the holes for the hitch and the noise should go away and make sure the hitch is on the ball tight there might be a adjustment nut under the tounge on trailer tighten it tell it fits good and snug.
bc toys
Images: 42
Postby aggie79 » Fri Feb 28, 2014 9:57 am
Fantastic! :applause: :thumbsup: :applause: The tongue box really completes the design!
Postby jeporter25 » Fri Feb 28, 2014 11:49 am
Wow Drew this looks great. where did you source 5 foot wide aluminum? I am in Fremont and I have been looking without much luck.
jeporter25
Postby drewh1 » Sun Mar 02, 2014 7:01 pm
jeporter25 wrote:Wow Drew this looks great. where did you source 5 foot wide aluminum? I am in Fremont and I have been looking without much luck.
jeporter - Thanks to Dano, I got my aluminum at South Bay Metals in Gilroy. I thought the price was pretty good, about $80 for a 5' x 12' piece. I bought 1 5x12, 2 4x10's and 1 5x8 for the hatch, all .040. easy to work with. I can't find the number but will look when I get home. they don't deliver so a built some 10' supports for my Lexus and tied it down (see build thread), drove it home with no problems.
bc toys wrote:you can get a pin that fits tight in the holes for the hitch and the noise should go away and make sure the hitch is on the ball tight there might be a adjustment nut under the tounge on trailer tighten it tell it fits good and snug.
I did tighten the ball and ordered a lock for the pin, so hopefully that will help. Thanks for the tips!
aggie79 wrote:Fantastic! :applause: :thumbsup: :applause: The tongue box really completes the design!
Tom - thanks for your complements. I am really glad I put the extra effort into building the tongue box, plus I had a lot of wood and aluminum left over anyway. Wait till you see the lid . . .
Almost done!!!!! 8)
drewh1
Images: 7
Re: Noise from hitch
Postby dodgedartgt » Sun Mar 02, 2014 8:32 pm
From your comment "...bangs around a bit on bumps...", I'm inclined to believe you don't have sufficient tongue weight. Be sure there is no play between the coupler and the tow ball. Also, when you flip the tow bar to raise the ball, simply raising the nose of the trailer will by itself reduce tongue weight even further. As previouslt mentioned, there are drawbar pins and locks which will elininate any play between the drawbar and the hitch. Still, my mind comes back to it banging and rattling around because it doesn't have enough weight on it.
Mike in FL
dodgedartgt
Postby drewh1 » Sun Mar 02, 2014 8:58 pm
dodgedartgt wrote:From your comment "...bangs around a bit on bumps...", I'm inclined to believe you don't have sufficient tongue weight. Be sure there is no play between the coupler and the tow ball. Also, when you flip the tow bar to raise the ball, simply raising the nose of the trailer will by itself reduce tongue weight even further. As previouslt mentioned, there are drawbar pins and locks which will elininate any play between the drawbar and the hitch. Still, my mind comes back to it banging and rattling around because it doesn't have enough weight on it.
Mike in FL
Hi Mike,
That sounds right to me too. I took it out before adding the tongue box and battery. That is going to add about 80 lbs I suspect. (I think the battery is 60 #'s by itself). Hopefully that will create the proper ratio of tongue to wheel weight. It seems to me the NT trailer does have it's axle a bit more forward than many of the designs I have seen.
drewh1
Images: 7
Postby citylights » Sun Mar 02, 2014 9:33 pm
Looks great! I really like the star view window up front. I wish I had dine that! Maybe a remodel project in my future? Hmmm.
You got lots of advice on the trailer tongue. I was going to suggest the same, there should be a nut to adjust the coupler on the ball to make it tight. One thing I did not see mentioned, make sure you have the right size ball for the hitch!
citylights
Users browsing this forum: Bing [Bot] and 11 guests
