lthomas987 wrote:With the trailer levelish how high is the top of your 1x4 frame from the ground? I'm curious. I have the same trailer but it is stored away from my house at the moment and I haven't seen it in months. Once the spring thaw comes though I am going to start building a 5x8 foamy on it. So you shouldn't be surprised that I am watching your build very carefully.
Laura
KCStudly wrote:Cool! (Pun intended.)
Why convert AC to DC if you are already going to have a battery on board? The only reason I can think is because you will only be running the A/C with shore power and you don't want the booster blower to draw your battery down; but if you are running shore power won't your battery be on a charger? Is there a 120v blower that could have done the job?
KCStudly wrote:Understood.
How will you protect the A/C unit from moisture damage from driven mist/rain? This is why I like what OakInteriors is doing with the under slung rail that will allow him to slide his unit out from under the TD easily for dry storage while going down the road.
KCStudly wrote:I'm curious about the wooden side frame rails. They appear to run long at the front. Will those get trimmed off later or does something else go there?
KCStudly wrote:Several people have had problems when they boxed in the sides of their A/C's. Make sure you have figured out which air goes where for condenser cooling/exhaust, and makeup air/recirculation. Just having one hatch to the rear sounds like it may be too restrictive (based on what I have read of other peoples installs). IIRC, I have seen some people have to add dividers to
the side grilles to keep the air patterns from mixing.
On the other hand, you seem to be smart enough to figure it out, once you have studied what other people have done to correct the issues that they have had.
I seem to recall Big Mike having to hack up (redesign) one of his installs due to this issues. There have been others, too.
KCStudly wrote:The problems that most people have seem to be recirculation of the hot air from the condenser. If the air being drawn in to the sides and top has to come past the exhaust, it can drag that hot air back in. The other problem people seem to have is icing up, which, IIRC, comes from failing to recirculate the conditioned air.
Again, this is just from my memory and may not be 100/ct correct. I don't have any plans to run an A/C, at least for now, so I haven't studied these issues in earnest, but I have read enough to know that it is seldom as easy to "hack" an install as it seems that it should be (hack = anything other than straight thru wall install where air is redirected from factory design). Learning from those that have gone before is worth the time, and can be every bit as stimulating as video games.![]()
You're doing a good job so far. Keep at it.
