We met up with the Chesapeake Tearjerkers last night for the first camp-out of the season. I got a bunch of good ideas, I really liked the
Magnadyne dual 12v/dual USB unit, it has a flat bottom, screw holes and instructions for permanent wiring so it is a nicer solution than several other options I was looking at.
I put two coats of paint on the tongue parts and visible parts of the frame today (I've heard the HF paint fades to pink in time, so that had to be corrected). I'm really glad I had a good respirator from some previous work, the fumes from Rustoleum's hammered finish paint are incredibly nasty.
I also opted to buy several cheap brushes instead of investing in a gallon of xylene to use as a thinner/cleaner since I doubt I'll ever use this stuff again.
I've been researching fiberglass/epoxy while waiting for the paint to dry, I had a bunch of questions so
I posted them in the teardrop construction forum.
Next up is electrical planning.
Rough design:
-120v duplex plus one of the Magnadyne units on each side of the bed
-Two 120v duplex outlets and another Magnadyne in the galley.
-Duplex 120v outlet and two 12v outlets on exterior of tongue box, so we can power our
12v drop lights while making camp or playing cards out of range of the porch lights even if the galley and cabin doors are closed.
I have to call the plywood vendor tomorrow to find out what their stock levels are and if out of stock, the lead time for delivery. I can't make much progress on the floor without the plywood to build the under floor storage or wheel wells. I also have to figure out what I'm doing with the extra two stabilizer jacks I ended up with, I might be able to run them from the stock tongue to the extension, but then I'd have to make sure the tongue box covers their jack screws or else someone might get an uncomfortable surprise while walking around the camper in the dark.
I plan to make saw dust next weekend with the under-bed framing. Finally.
