another foamie build thread
Re: another foamie build thread
Postby GPW » Thu Mar 13, 2014 5:28 am
The smaller panels might be easier to handle , although both would work eh ? :thinking:
Postby KCStudly » Thu Mar 13, 2014 7:01 am
I haven't got to that point in my build yet, but will be using two layers of 3/4 thk x 2 ft wide foam running across wise. I'll need to experiment a bit with dry fitting to see which way I want to do it (place each piece separately vs. smaller panel glue ups), but I doubt that I will do it as one big glued sheet.
My reason for thinking that across wise is better is because each seam will be shorter and therefore easier to sand/fair the joints. Also, if the joints aren't perfectly fair after sanding and they telegraph thru the canvas outer skin, I think it would be less ugly for them to go across wise, giving a spar like appearance, rather than stripes like a skunk (stinky looking to my eye). Randomly placed lines across wise would look better than randomly (non-symmetrical) lines running lengthwise.
The tight radius at the front might be done with longer glued up panels, kerfed back to back if need be.
Postby scuba1978 » Thu Mar 13, 2014 8:04 am
Great points guys. I do intend to kerf the radii either way. Perhaps a skunk would be a cool color scheme!
scuba1978
Images: 23
Postby GPW » Thu Mar 13, 2014 1:44 pm
Using two layers you could stagger the joints :thinking: ... Unless you lived in Colorado , where the joints could stagger you .... :o :roll: :lol: :lol: :lol:
Postby scuba1978 » Mon Mar 17, 2014 9:03 pm
Yesterday I welded the rear trailer jack on the frame. And I glued on the walls.
There were a few gaps, so I covered them with painter's tape, and I poked the nozzle of some great stuff into the gap and filled them up. It worked great except for one blowout.
I let it cure overnight, then I got after it!
scuba1978
Images: 23
Postby scuba1978 » Mon Mar 17, 2014 9:11 pm
Today, I cut the front-top-rear panels into 73" x 24" panels, then glued them into 3 larger panels. I then cut a 1" shoulder all along the inside edge of the walls. I made a sweet gage to mark it, then cut it with a razor.
Those are the glued panels behind the wall. I cleaned up all of yesterday's glue expansion. Finally, I made a hot wire kerf gun.
I also glued in a ceiling brace over the doors. Tomorrow should be a roof, and maybe some bracing for the fan..
scuba1978
Images: 23
Postby GPW » Tue Mar 18, 2014 5:10 am
Great progress Scuba !!! 8)
Postby scuba1978 » Tue Mar 18, 2014 4:15 pm
Thanks GPW! I went and bought door hinges and rubber gloves today, then I started kerfing the first radius.
scuba1978
Images: 23
Postby scuba1978 » Tue Mar 18, 2014 6:17 pm
Layed some gg in the slots, and bent 'er up!
Image. That's probably all for today!
scuba1978
Images: 23
Postby kudzu » Tue Mar 18, 2014 7:07 pm
You're making good progress. :thumbsup: The bunk is getting a nice test. :)
kudzu
Images: 16
Postby GPW » Tue Mar 18, 2014 8:34 pm
That bent Nicely didn’t it !!! 8)
Postby tac422 » Wed Mar 19, 2014 6:02 am
That looks Great :applause:
tac422
Postby scuba1978 » Wed Mar 19, 2014 11:24 pm
GPW wrote:That bent Nicely didn’t it !!! 8)
It did, but I may try a new kerf tecnique. The gun I used was tricky, and it left uneven kerfs which bent unevenly, and some places cracked because of it. It was still reletively easy, but it required/s e great deal more glue and hand-finishing to get a nice surface. I'm not trying to build the Taj Mahal, but I want a certain moderate level of aesthetic finish work. I did not attach the curved piece yet, I used painter's tape to cover the walls, then used them as a form to glue the radius. I felt like it would have been a bit difficult to glue everything at once. Now, I can put the pre-formed radius on after some love with a flapper wheel.
No real progreess today...went fishing. Caught nothing but a :beer: mild buzz from a cigar and a few sips of some nice scotch a friend gave me!
scuba1978
Images: 23
Postby GPW » Thu Mar 20, 2014 4:48 am
Scuba, I’m now thinking for kerfed /rounded surfaces , problem could be prevented by first gluing on a LIGHT material (old sheet) on the outside surface to be bent ... relieving the tension stresses , and making the bending safe ... no cracking , leaving a smooth outer surface ... :thumbsup:
Postby lthomas987 » Thu Mar 20, 2014 9:22 am
Scuba,
Are you just using a solder gun with a block of wood to fix your depth as a foam cutter for doing your kerfs? Or is there something else going on there that I am not seeing?
Laura
Laura
Bike-Drop a Micro-Foamy Build Journal http://www.tnttt.com/viewtopic.php?f=50&t=59274
My first Superlegarra-ish Foamy build http://www.tnttt.com/viewtopic.php?f=55&t=59049
lthomas987
Images: 204
Users browsing this forum: DrAlvarez and 10 guests
