jae wrote:I couldn't find any info after a quick forum search, so I figured I'd stick this here and see if any of you guys have heard of it, or know if it'd be worth trying. Just a tad cheaper than the pink stuff here locally, and at 1/2" thick it's still rated for structural use. This tells me that it might be a bit heavier than standard foam, but if you could get the strength of 2" thick pink (or blue, or green, etc) out of a 1/2" sheet it might be worth it.
http://www.homedepot.com/p/Unbranded-Qu ... /202089176
GPW wrote:Moulded fiberglass parts would be really Terrific for Foamies , just door and window frames is all that’s needed reallyMaybe just a length of correct fitting fiberglass moulding that could be cut to fit and glued into place ... That would be Nice too ...
Many possibilities eh ? ...
Har’, all the PVC fence posts are 4” X4” and larger... but they do make a 2” X 6" , that could be made into an end channel by sawing off one of the edges...
http://www.lowes.com/pd_87348-73428-730 ... facetInfo=
Jack B. wrote:On a non-trailer but foam and wood idea. I'm thinking 'bout building a pedal powered catamaran and have a couple of thoughts/questions for (I suppose) the Geepster. My idea for the two hulls is to make plywood "I" beams with the top being wider than the bottom. Bathe them in the solution a few times and then do layers of foam sheeting between the top and bottom on each side to form the pontoons. Cover with a couple layers of fabric, glue and paint and add a thin metal strip along the bottom and up the front for protection. The idea is the front to back plywood would help with strength and rigidity while the top plank gives something to screw/bolt/attach to while the bottom plate helps with rock, sand and hauling abrasion strength.
My question is, do you think that's enough protection from water? Pretty sure that I should use the pink or blue instead of bead board to cut down on water intake with the foam. This thing wouldn't sit in the water all the time, rather it's a few hours pedaling and then back in the garage or whatever. Of course if it works out then there could be a bigger one for longer time usage, but the way my plans go - baby steps, just baby steps.
Jack
Users browsing this forum: Bing [Bot] and 18 guests
