2000 watt generator
2000 watt generator
Postby ValerieP » Tue Mar 25, 2014 7:11 pm
We decided that we could survive just fine with a 2000 watt generator and have been looking around at prices-I thought the best was around 600 and then I found this on Amazon
Champion Power Equipment Inverter Generator - 2000 Watt, Model# 73537i
by Champion
Be the first to review this item
Price: $499.00 + $31.49 shipping
Only 19 left in stock.
Ships from and sold by SuperGen Products.
http://www.amazon.com/Champion-Power-Eq ... MX2A3JZBHF
I don't know if anyone else is looking but I thought I would share- it runs at 53db and that's as quiet as I can afford!
ValerieP
Images: 7
Re: 2000 watt generator
Postby jwhite » Tue Mar 25, 2014 7:29 pm
I like the Honda 2000 because they have a extended run gas tank that holds 6 gallons of gas and it will run for days without having to shut it off.
I run mine in the summer to run a 8000 btu window AC and I never shut it off,you can add more gas to the tank without shutting the generator off.
They can also run on propane and hook them together for 4000 watts.
they cost more but I think they hold there value and will have no problem selling it, I watched enough of them on ebay sell at a good price.
jwhite
Images: 46
Postby OverTheTopCargoTrailer » Tue Mar 25, 2014 11:38 pm
I almost bought one, they are pretty quiet , but not as quiet as the Honda 2000.
BTW jwhite the Honda 2000 is rated at 1600 max long term running load. 2,000 max load.
It's the same with the champion
I just got the Honda - but if you will only use it every now and then the Champion should be fine.
If you run it day & night then get the Honda.
Both can be converted to also run on Nat gas or propane for a few hundred $$$$ :thumbsup: :thumbsup:
Good luck !!
Postby ValerieP » Wed Mar 26, 2014 4:41 am
Thanks-the price was just so odd, there are at least 3 models of the Champion 2000 53dB and the price varied as much as 200 between them, so of course the one we chose was the least expensive. We are camping in Maine this summer and the state parks don't have electricity, so we will use it in the evening to charge our electronics, and cook a little. We probably won't run it more than 3-4 hours a day. We will be without electricity for about 3 weeks or so throughout the summer.
Just curious, anyone know any free camping in the Aroostook area of Maine? I haven't reserved the campground there yet.
ValerieP
Images: 7
Postby Glenlivet » Wed Mar 26, 2014 7:42 pm
I have that very Champion generator and it is perfect. There is a huge thread on them at Woodalls
http://forums.woodalls.com/index.cfm/fu ... age/67.cfm
Glenlivet
Postby ValerieP » Thu Mar 27, 2014 4:25 am
Good to hear! Thanks, it should be here in a few days, then we will test it out. I will post pics on our trailer build thread when it arrives, we have done a couple of things to the trailer so it won't hurt to update that thread ;)
ValerieP
Images: 7
Postby norcal2 » Fri Mar 28, 2014 3:54 pm
I have 2 honda e1000i i hook together if I need 2000 watts, most time one works just fine, if i know im going to need 2000 watts ill load the second in the rack..otherwise i use 1 just fine, let us know how these Champions hold up!
norcal2
Postby dpjeansonne » Sun May 04, 2014 7:37 pm
I just could not justify the cost of the Honda for the few times I need it. Mostly I plan to use parks that have power.
I bought a used Generac 2000 which can run at 2000 and surge 2200. It is not as quite as the Honda but you can find these at about $540 new. I paid $400 and it was very close to new.
I am happy with it.
dpjeansonne
Images: 20
Postby flboy » Thu Jun 19, 2014 8:19 pm
I've tried a few small generators and finally just bought the Honda EU2000i. I got the best deal I could find on http://www.electricgeneratordepot.com. $899.99 delivered. No tax or shipping. I started it up today... wow this is quiet.. I turned on a 1500W heatgun and the voltage never dropped. I can't wait to try it out while camping. I bought another gas cap on Amazon and I have an old 6 gallon outboard boat motor gas tank. I am going to make the extended run gas tank.
I was really struggling whether to buy the Champion or the Hyundia as both were a few hundred less.. but the Honda's have such a great reputation and are just reliable long term. I plan to have ot for a while. Time will tell if the extra $300 - $350 Honda premium was worth it. I like the fact there is a 3 yr warranty.
Don (Flboy)
https://youtu.be/6_-8cVdWUIA
https://youtu.be/MUcMM86LA2g
flboy
Images: 378
Postby astrotrailer » Fri Jun 20, 2014 1:57 pm
I work at a university in IT. We install our outside fiber optic cable and use the Honda 2000 to run the pump to pull water out of vaults or the blower to ventilate vaults when entering them. Our Honda has been going for 11 years with no problems. Nice and quiet so Faculty don't complain when using near a classroom with open windows.
I camp where air conditioning isn't needed so solar power meets my camping and astronomy needs. I like not having to deal with generator or gas and the solar keeps my batteries topped off. If you need air conditioning or a microwave and you aren't at a campground with power, the quiet generator is the way to go. I think it is just good manners not to buy a cheap noisy generator and run it for hours near other campers. Most people are just too polite to complain, but everyone enjoys the quiet once they are turned off.
astrotrailer
Postby flboy » Sat Jun 28, 2014 8:50 am
Good point on the noise. That was one of my biggest concerns. I know the old generator was noisy and even though I could place it away from me, I was concerned about the overall impact.
Don (Flboy)
flboy
Images: 378
