"Gocamp" a 4x8 hf build (first trip finished)
Re: New start 4x8 hf build unnamed yet
Postby absolutsnwbrdr » Fri Mar 21, 2014 8:39 am
Nice work! I like the carpet. Looks like you may have build a speaker box or two before this. I'm with KC - I like the profile because its different from the norm, but its also not just a plain box. :thumbsup:
Zach
Coming Soon...
absolutsnwbrdr
Images: 412
Postby Glenn Butcher » Fri Mar 21, 2014 12:30 pm
I like the carpet treatment, too. Probably going to do it on my upcoming build.
Glenn Butcher
Images: 16
Postby jbyrd » Fri Mar 21, 2014 4:20 pm
absolutsnwbrdr wrote:Nice work! I like the carpet. Looks like you may have build a speaker box or two before this. I'm with KC - I like the profile because its different from the norm, but its also not just a plain box. :thumbsup:
Thank you! yeah I may have built a couple, I worked in car stereo almost 10yrs.
Glenn Butcher wrote:I like the carpet treatment, too. Probably going to do it on my upcoming build.
I love how it turned out and it should add some insulation factor and something a little more comfy to rub up against in the middle of the night.
Til later, See ya
Jeremy
My build journal #1 "SOLD" : viewtopic.php?t=45945
my build journal #2 "SOLD": viewtopic.php?f=50&t=59216
jbyrd
Images: 172
Postby jbyrd » Fri Mar 21, 2014 4:42 pm
Ok so I managed to get a far amount done today.
Would have got more done but had to wait on spar varnish to dry.
So I got the roof spars cut and carpeted
and installed
which allowed me to get the roof on :)
an inside shot. I think it turned out pretty well.
I made one more goof I forgot to cut my power cord opening :?
a shot of the entire trailer out in the open. That trailer to the side of it has all of my aluminum on it to keep it flat
so I went and spar varnished all of the seams and screw heads.
I figured more protection couldn't hurt.
while i was waiting on that to dry I built some inside shelves for small things and phones,etc.
And installed my power box, although the pictures makes it look crooked I will have to check that tomorrow.
So I should be good to start skinning it with aluminum tomorrow. :applause:
Til later, See ya
Jeremy
jbyrd
Images: 172
Postby Patrickteardrop » Sat Mar 22, 2014 9:14 pm
I might just have to use the same material to cover my interior walls. I haven't given a lot of forethought to that up to today, as I've been concentrating on my frame. Very nice storage! I too, like the profile and your choice of door.
My Project Teardrop - 1946 homebuilt(?) 4x8 camper...under reimagination!
Patrickteardrop
Images: 15
Postby jbyrd » Sun Mar 23, 2014 8:46 am
So......I didn't get as much done as I would have liked.
only got three sides skinned in aluminum before my helper A.K.A my wife had to leave.
since the top and front are all one piece I knew there was no way I could manage it myself.
I used contact cement to adhere the walls on. As you can see from the first picture I have
been boarding up all the openings every night as we have stray cats around that like to mark everything as "theirs". :thumbdown:
I did find that routing aluminum is NO FUN there has to be a better way to do it....I'm just not sure what that is :NC
So probably no more progress for a couple days as its calling for rain today and tomorrow
Til later, See ya
Jeremy
jbyrd
Images: 172
Re: "Gocamp" a 4x8 hf build
Postby jbyrd » Sun Mar 23, 2014 5:32 pm
Ok so this crazy florida weather decided to cooperate with me today and only rained about 30 mins.
So I was able to get some more done.
Got the top and front A.L. on
and got the door cut out routed. I have got alot of vacuuming to do after this
and installed putty tape on the door
and TA-DA I have a door :D
also a power port
I keep joking with my wife if she is gonna like camping in a pink trailer....she is not amused. LOL
Ok so if weather allows I will try to get the windows installed tomorrow but we'll see.
Til later, See ya
Jeremy
jbyrd
Images: 172
Postby S. Heisley » Sun Mar 23, 2014 11:35 pm
WOW! :o You are really moving fast on this trailer. The inside looks really good. I suspect the rug "lining" will be like wearing a sweater, insulation-wise. From the looks of how "clean" everything is, you've done work like this before!
Postby jbyrd » Mon Mar 24, 2014 7:57 am
S. Heisley wrote:WOW! :o You are really moving fast on this trailer. The inside looks really good. I suspect the rug "lining" will be like wearing a sweater, insulation-wise. From the looks of how "clean" everything is, you've done work like this before!
Thank you!
Yeah I designed this trailer to be built fast I worked out all of the details over a years time.
I have done a lot of car stereo work in the past which gave me the experience with the liner and wood working.
Til later, See ya
Jeremy
jbyrd
Images: 172
Postby jbyrd » Wed Mar 26, 2014 8:19 am
Well I did get to spend most of yesterday working on the camper.
I only got pictures of the windows though.
I had to install them with screws they were new windows but were missing the trim ring.
I used stainless screws and my cut out was super tight so the inside actually looks really good without the trim ring.
Also got all of the trim cut and installed yesterday but didn't get pictures as we had freezing
weather headed in and i had to run cover the entire garden.
Til later, See ya
Jeremy
jbyrd
Images: 172
Postby aggie79 » Wed Mar 26, 2014 5:25 pm
Fantastic! :applause: :thumbsup: :applause:
Postby jbyrd » Thu Mar 27, 2014 7:55 am
aggie79 wrote:Fantastic! :applause: :thumbsup: :applause:
Thank you very much!
Til later, See ya
Jeremy
jbyrd
Images: 172
Postby jbyrd » Mon Mar 31, 2014 5:32 pm
well I got some more done on the trailer almost finished now just a few more odd and ends.
I installed the a/c. It's not at that angle the picture was during installation.
I have it held in with the normal mount for the top and added a 3/4 angle aluminum piece to hold the bottom.
got it out in the open to get some better pics.
I still need to install some trim around the ac outside but I had to wait for the silicone to dry.
I started installing my graphics and mounted my tongue box still need to do the other side
and decide if i want to do some front graphics.
Oh and I got my solar motion light mounted that's what you see right in front of the door at the top.
I should have it all buttoned up tomorrow which is good since it's first trip will be next week.
Til later, See ya
Jeremy
jbyrd
Images: 172
Re: "Gocamp" a 4x8 hf build (almost finished)
Postby Woodbutcher » Mon Mar 31, 2014 6:45 pm
Great job, you move fast. Where are to going for your maiden voyage? :applause:
Woodbutcher
Postby jbyrd » Mon Mar 31, 2014 6:56 pm
Woodbutcher wrote:Great job, you move fast. Where are to going for your maiden voyage? :applause:
Thank you very much! We are going to St. Augustine fl.
Til later, See ya
Jeremy
jbyrd
Images: 172
