Patio Chairs
Patio Chairs
Postby VijayGupta » Wed Apr 02, 2014 11:19 am
I found some recycled cedar at Restore this spring and made up a couple of chairs for my wife for her birthday next week. I saw this design years ago and always wanted to build them. The seat half slips into the back to make a compact unit. Her first comment after, "Wow, they are comfortable," was "Can you make some footrests to match?"
Plans at https://www.minwax.com/wood-projects/pd ... e-seat.pdf
Edit: Link moved up to make it more visible.
VijayGupta
Re: Patio Chairs
Postby lrrowe » Wed Apr 02, 2014 11:27 am
I love these chairs. Have noticed them for years now.
They are going on my "to do" list.
Also am going to send the plans to my son to see if they would work good in a canoe.
Bob
Bob
lrrowe
Images: 439
Re: Patio Chairs
Postby jonw » Wed Apr 02, 2014 1:09 pm
Where did you get the plans for them?
Thanks.
jonw
Titanium Donating Member
Images: 163
Patio Chairs
Postby Verna » Wed Apr 02, 2014 3:15 pm
Jonw, the link to the Minwax plans are below the picture-- easy to miss.
Verna
Indianapolis, IN
Verna
Images: 49
Re: Patio Chairs
Postby 48Rob » Wed Apr 02, 2014 5:46 pm
Nice job! :thumbsup:
Rob
48Rob
Re: Patio Chairs
Postby jonw » Thu Apr 03, 2014 7:59 am
Verna wrote:Jonw, the link to the Minwax plans are below the picture-- easy to miss.
Got it - thanks. Any tips you'd care to offer from your experience building them?
jonw
Images: 163
Re: Patio Chairs
Postby VijayGupta » Thu Apr 03, 2014 9:45 pm
Tips:
1. I dislike doing the 1" block things. I used a bit of algebra and computed the radius of the curve and used a trammel to mark them out.
2. Used a stop on the drill press to precisely set the screw holes uniformly. Pilot hole and countersink for #8 1 1/4" exterior screws.
3. Use 1/2" plywood scrap top set the gaps between the slats.
4. Round over all edges with 1/8" router bit.
5. Use Titebond III to glue the two slats that hold the seat in place, for extra strength in addition to the screws.
6. Keep the grain as straight as possible, especially on the legs. Grain run-out will significantly reduce the strength of these pieces.
7. Put one screw in each end of all the slats. Then ensure everything's square and go back and add the second screw to each end.
VijayGupta
Re: Patio Chairs
Postby Vedette » Fri Apr 04, 2014 2:18 am
We have a set of 4 for years. They are great! :thumbsup:
Good Roads
Brian & Sandi
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
Re: Patio Chairs
Postby deleted » Sun Apr 06, 2014 8:16 am
Gorgeous! :thumbsup:
deleted
Images: 85
