Stainless Steel Micro-Airstream behind motorcycle
96: Stainless Steel Micro-Airstream behind motorcycle
Postby ST1100 » Sun Apr 06, 2014 4:41 pm
After cutting one more willow tree yesterday in my garden, today was trailerday.
First I completed the doorframe:
And sealed it with a self adhesive rubber band.
50 years camper and 35 years biker !
1977 Eriba Troll
2001 Honda GL1800 with trailer hitch, Ford Focus Pininfarina Convertible with hitch
ST1100
Images: 199
97: Stainless Steel Micro-Airstream behind motorcycle
Postby ST1100 » Sun Apr 06, 2014 4:44 pm
Then I fitted the door skin and drilled all the holes into it.
Next was deburring and drilling thru into the frame of the door and fitting the edges again.
1977 Eriba Troll
ST1100
Images: 199
98: Stainless Steel Micro-Airstream behind motorcycle
Postby ST1100 » Sun Apr 06, 2014 4:51 pm
Last step was to degrease all and seal the frame with sikaflex.
I attached the skin with clecos in every second hole and riveted between them.
Then I removed the clecos and finished riveting.
1977 Eriba Troll
ST1100
Images: 199
Re: Stainless Steel Micro-Airstream behind motorcycle
Postby S. Heisley » Sun Apr 06, 2014 4:57 pm
...So very,very nice...A work of art. :thumbsup:
Will you insulate the inside, etc. or is this it for now?
Postby ST1100 » Mon Apr 07, 2014 1:37 pm
S. Heisley wrote:...So very,very nice...A work of art. :thumbsup:
Thanks Sharon - first 16 day test without insulation - maybe later !
1977 Eriba Troll
ST1100
Images: 199
Postby alaska teardrop » Mon Apr 07, 2014 4:05 pm
    Very well done, Tom. :thumbsup:
    I'm curious to learn the weight at this point before adding your camping equipment?
    Fred
alaska teardrop
Postby Patrickteardrop » Mon Apr 07, 2014 8:07 pm
What a beautiful trailer!
My Project Teardrop - 1946 homebuilt(?) 4x8 camper...under reimagination!
Patrickteardrop
Images: 15
Postby jae » Thu Apr 10, 2014 11:04 am
It certainly looks nice, my only question is if you have vents for air flow? I don't recall seeing any.
jae
99: Stainless Steel Micro-Airstream behind motorcycle
Postby ST1100 » Sun Apr 13, 2014 4:33 pm
This week I added a handle and a lock to the door.
And today I completed the front with the spare wheel, to bring five more kg weight onto the tongue.
1977 Eriba Troll
ST1100
Images: 199
100: Stainless Steel Micro-Airstream behind motorcycle
Postby ST1100 » Sun Apr 13, 2014 4:44 pm
And - I hooked it to my bike and made a one hour test ride over narrow mountain streets, high speed autobahn with strong winds and passing trucks.
The trailer follows very fine, I reduced trailer tire pressure a bit to reduce the clonks when I pass a bridge.
Tested up to 130 km/h and felt only a small swinging when reducing speed from 130 !
Perfect between 80 and 100 km/h.
Trailer weight is now 128 kg (282 lb) and five more kg adding the spare wheel.
1977 Eriba Troll
ST1100
Images: 199
101: Stainless Steel Micro-Airstream behind motorcycle
Postby ST1100 » Sun Apr 13, 2014 4:51 pm
Back at home I separated the sleeping box from the base camp to install the final connections between both parts in the evening.
Weight of the cabin is exact 50 kg (110 lb) !
1977 Eriba Troll
ST1100
Images: 199
Postby PKCSPT » Sun Apr 13, 2014 5:22 pm
Looks great :clapping hands:
121172 116946 159644
PKCSPT
Images: 61
102: Stainless Steel Micro-Airstream behind motorcycle
Postby ST1100 » Mon Apr 21, 2014 4:59 pm
Okay - last weekend before starting my journey to Spain.
Bought a sheet of blue self adhesive Oracover and nine self adhesive letters and cut a stainless plate.
After an evening I got this:
1977 Eriba Troll
ST1100
Images: 199
103: Stainless Steel Micro-Airstream behind motorcycle
Postby ST1100 » Mon Apr 21, 2014 5:04 pm
Next was to mount the poles to balance the trailer if not hooked to the bike.
Bad weather outside on friday, but inside my garage no problem.
On Saturday I did nothing at the trailer, because I had a full day motorcycle safety driver training at best weather from 9 to 5 !!!
1977 Eriba Troll
ST1100
Images: 199
104: Stainless Steel Micro-Airstream behind motorcycle
Postby ST1100 » Mon Apr 21, 2014 5:07 pm
First on Sunday i installed the connections between trailer platform and sleeping box.
1977 Eriba Troll
ST1100
Images: 199
