7 X 12 V-Nosed CT First Conversion
Postby James06 » Sun Apr 20, 2014 5:11 pm
Ok, this will be my first conversion attempt. I'm not sure if this is the right place, so if it's not, please feel free to move it to the appropriate section. I've bought a few things, but the trailer is not here yet :( . So far I have purchased an Atwood 55 amp power distribution/ charger, a 30 amp cord and power inlet, 12 volt camper lights, outlets, 3 wall cabinets I plan to use as floor cabinets, wire baskets for shelves, D rings, cots. Here are a couple of pictures of some of the stuff.
119279
119278
James06
Images: 24
Re: 7 X 12 V-Nosed CT First Conversion
Postby Rainier70 » Sun Apr 20, 2014 10:13 pm
Looks like you will be ready to roll the minute your trailer is done. When do you pick it up?
Rainier70
Images: 244
Postby James06 » Mon Apr 21, 2014 8:38 am
It's supposed to be in between Thursday and Monday, but the dealer has to install the bed bolts. He charged $5 each for installation, which is better than me crawling around under the trailer since I'm fat. I went with bed bolts instead of traditional tie-downs because I want to be able to have a smooth floor when I'm camping. He will countersink the bolt head so they are flush. I'm having 6 put in as tie downs and 4 where my wheel chock will go for the bike.
James06
Images: 24
Postby lrrowe » Mon Apr 21, 2014 10:06 am
Hi James,
I am curious as to what brand of CT you purchases in TN?
Thanks,
Bob
Bob
lrrowe
Images: 439
Postby James06 » Mon Apr 21, 2014 10:27 am
I got a Homesteader Patriot.
James06
Images: 24
Postby lrrowe » Mon Apr 21, 2014 11:35 am
Thanks, and I am sure you are going to enjoy it.
Bob'
Bob
lrrowe
Images: 439
Postby James06 » Tue Apr 29, 2014 6:46 pm
The trailer is in! I rode the bike up there this evening so they could get the chock position right. They are putting the bed bolts in tomorrow and I should be able to pick it up Thursday or Friday.
James06
Images: 24
Postby bc toys » Wed Apr 30, 2014 7:34 am
nice that you are getting your trailer this soon you will be camping in no time :thumbsup: :thumbsup:
bc toys
Images: 42
Postby lrrowe » Wed Apr 30, 2014 8:04 am
:thumbsup: :applause: X2
Bob
lrrowe
Images: 439
Postby James06 » Wed Apr 30, 2014 8:44 pm
Here are a few of the blank slate pictures.
119654
The window is 24"
119655
This is a possible location for the cabinets
119656
The ceiling is pretty flat.
119657
James06
Images: 24
Postby James06 » Thu May 01, 2014 10:19 pm
I put a coat of primer on the floor. Tomorrow will be a coat of two-part epoxy, followed Saturday by clear epoxy. My wife plans on taking the dog with us, and I want to make sure the floor is "mistake-proofed".
James06
Images: 24
Postby James06 » Sun May 04, 2014 8:55 pm
The floor is painted with 2- part epoxy and a clear coat. I will have to touch up a few spots, but I will do that later.
119842
That's my son-in-law and daughter looking at the trailer. We also added wire baskets as shelving and started painting the walls with a gallon of paint we got at Lowes on clearance. They had mixed the wrong color, so we got a gallon of $45 paint for $15.
James06
Images: 24
Postby James06 » Tue May 20, 2014 10:11 pm
I haven't posted in a while, but have an update. The wiring is mostly pulled, with the 12 volt lights installed. I still need to install the outlets and hook everything up to the converter. I will post some pics later.
James06
Images: 24
Postby James06 » Sat May 24, 2014 8:45 pm
We now have electricity. I also had a friend bring me enough foam to probably insulate the ceiling. I will porbably do that Monday and start on the countertop. I amu using poplar that my uncle sawed into boards. I found some with a beautiful grain. I will try to post pictures tomorrow.
James06
Images: 24
Postby flboy » Sat May 24, 2014 9:23 pm
Looking good. Are you going to add AC, water and all that.. or just basic place to sleep out of the weather?
Don (Flboy)
https://youtu.be/6_-8cVdWUIA
https://youtu.be/MUcMM86LA2g
flboy
Images: 378
