woodywrkng wrote:I win the prize for smallest bit, at 1/8", in a RotoZip. Such a small bit ensured a small gap between door and wall.
I used the same tool and bit, except that I cut out both doors at the same time... 3/4" stacked on 3/4" plywood.
- DOOR CUT-OUT.jpg (60.36 KiB) Viewed 527 times
It was a bear to cut, and I had to sand both sides of the cut significantly (in some places) to "smooth" them out. Ended up with a variable width gap all around, from 1/8"
+ to 3/32"
- DOOR CUT-OUT GAP.jpg (120.13 KiB) Viewed 527 times
Fortunately, the automotive doorseal I used doesn't care! I would not repeat that mistake (even though I later cut out the holes for my windows and A/C, albeit from a single thickness of 3/4", using the same tool) I would probably get a Dremel Saw-Max,
- Saw-Max.jpg (17.75 KiB) Viewed 527 times
if I were to repeat.
