hankaye wrote:AZ_Desert_Rat, Howdy;
AZ_Desert_Rat wrote:Hi Cindy,
I like the insulation of the floor cavities --- Please keep us posted as to how well they work and hold up. I need to insulate mine as well, the heavy rubber-backed carpet helps, but is no match for really cold camping ...
![Snow :snow](./images/smilies/Snowing.gif)
Exercise your options and don't camp where it gets below your comfort temp. ...
hank
I know this was kidding, but for me I don't always have those warm weather options. I need to leave the valleys when the air gets bad for me just about anytime of the year. That means during early spring burning etc. Both the farmers and the forest service have been burning off and on since mid April. Which is fine, they need to, but I have to get up higher and out of it. The same goes for late fall when many fields etc are burned again. The latest I had to leave and camp was about 20th of Nov last year. The weather at 7 to 10 thousand feet is iffy and usually very cold early in the spring and late in the fall. So my camper needs a bit more insulation than most.
I think that the cold coming through the floor that froze my water bottle this last time was made worse because there was a good "breeze" going. Thus the "wind chill" was lower than the actual temp outside. I figure that the underside of my ct is much like a cot. If you have ever slept in a cot in the cold, you will know that you have to put a lot of insulation under you or the cold air under will suck the heat right out of your body.
A few other people also camp in the high elevations such as Idaho, Wyoming, or Colorado. What I am doing with my ct may be of help to some of them also.
