Roof aluminum thickness
Postby Jdhiker » Wed Apr 23, 2014 1:46 pm
Sorry I couldn't find in a search for some reason. What thickness is recommended for the aluminum for the roof? Hoping to go buy a few sheets today.
Jim
Jim & Charlene
Belchertown MA.
Working on Benny the "Shasta Mini" !! to be pulled behind 2012 Honda CRV
Blog, http://www.jdhiker.wordpress.com
other campers I'm working on
64 Beeline Wasp
66 Shasta compact
and out family Standee is
26' 2012 Keystone Summerland towed with a 2003 GMC 2500HD Crew CAb
Jdhiker
Re: Roof aluminum thickness
Postby Jdhiker » Wed Apr 23, 2014 2:42 pm
Well decided to go with .032. Seemed like it will work just fine
Jim & Charlene
Belchertown MA.
64 Beeline Wasp
66 Shasta compact
Jdhiker
Postby Jdhiker » Wed Apr 23, 2014 9:29 pm
Here is the roof on. Diamond plate rock guard going on lower front....fantastic fan installed. Now need to order the moldings
Jim & Charlene
Belchertown MA.
64 Beeline Wasp
66 Shasta compact
Jdhiker
Postby Gage » Thu Apr 24, 2014 12:37 am
What are you going to do about edge trim/molding? Did you forget about that? :thinking:
Image Image Image
Gage
Images: 28
Postby Jdhiker » Thu Apr 24, 2014 7:21 am
Have roof edge trim with insert type coming. Wide enough with the Rv tape under should seal fine, I measured and all the staples will be covered with plenty of sealed trim over.
Also going to have a diamond plate in the lower front.... I guess an aluminum trim with the sealant under to make the transition from roof to rock guard.
Jim & Charlene
Belchertown MA.
64 Beeline Wasp
66 Shasta compact
Jdhiker
Postby Jdhiker » Thu Apr 24, 2014 7:23 am
The shell of this trailer was already built when I got it. Next one I build will be the right width for a full sheet to go edge to edge.....
If I plan on a 5 wide I guess the sheets have to go across with seams????
Jim & Charlene
Belchertown MA.
64 Beeline Wasp
66 Shasta compact
Jdhiker
Postby tony.latham » Thu Apr 24, 2014 10:53 am
"If I plan on a 5 wide I guess the sheets have to go across with seams????"
You should be able to get 5 wide sheets of aluminum for a 5-wide.
My first teardrop was factory built. I was surprised to find it's roof had .063 on it with no underlying plywood. It lived through several nasty hailstorms with at least 3/4" bombs. No dents. My build from last summer has .040 on it and I'll be crossing my fingers with it's first hail storm. I'd like to hear what other's have experienced. I think some of this issue must involve the hardness (alloy) vs. thickness of aluminum.
Postby woodywrkng » Fri Apr 25, 2014 7:54 am
I used .040 aluminum over 1/8" baltic birch plywood. It lives outdoors and has seen hail with no problems.
woodywrkng
Images: 35
Postby Jdhiker » Fri Apr 25, 2014 8:16 am
I heard that the typical vintage trailer skin is .030.
Jim & Charlene
Belchertown MA.
64 Beeline Wasp
66 Shasta compact
Jdhiker
Postby jonw » Fri Apr 25, 2014 8:35 am
Also used .040in. aluminum for roof/front/back. Pretty sturdy stuff - not easily dented...
jonw
Titanium Donating Member
Images: 163
Postby Esteban » Fri Apr 25, 2014 12:24 pm
If you are looking for 5 root wide aluminum sheets saf.com is an aluminum supplier that sells 5 foot wide sheets in several thicknesses and lengths. I had them bookmarked.
Steve - SLO, CA
Esteban
Images: 15
Postby DMcCam » Sat Apr 26, 2014 12:27 pm
We wanted low maintenance which meant anodized aluminum. We also needed 5' wide stock and didn't want seams. The only thickness we could find on the west coast long enough to cover was .063, so that's what we did. It's very sturdy and hard to bend to a tight radius. If you do need to bend it to a tight radius, buy a couple of sheets of 1/8" or 3/16" 4'x8' Masonite, take it to a sheet metal shop with a roller and have them pre-bend it for you. Sandwich your aluminum between the Masonite to protect it from damage (scratches and gouges) from the roller. .063 anodized aluminum is amazingly strong but will still scratch.
Cheers,
Dave
DMcCam
Postby eggsalad » Sat Apr 26, 2014 1:31 pm
I've used .032 aluminum over 3/16" Masonite.
eggsalad
Users browsing this forum: Google [Bot] and 1 guest
