Modified 2+2 trolley top - Dinette Table - pg 15
Re: Modified 2+2 trolley top - wiring and insulation -pg 11
Postby danlott » Thu Apr 24, 2014 5:07 pm
I have finished the wiring in the roof and completed the insualtion. I used 2 layers of 3/4" foam on the main roof sections and 2 layers of 1/2 inch foam in the trolley top section. Now on to the outer layers of plywood.
Dan
Hoplite Traveler Build thread
danlott
Images: 264
Postby Gunguy05 » Thu Apr 24, 2014 5:11 pm
Hey! Glad to see you are back in action.
That's a beautiful foam job you did there. Looks almost good enough to eat!
Keep the pics coming. Full speed ahead!
Brian
Gunguy05
Images: 6
Postby S. Heisley » Thu Apr 24, 2014 6:41 pm
...Looking great, Dan. This is going to be a really nice teardrop. :thumbsup:
Postby Gunguy05 » Thu Apr 24, 2014 6:56 pm
Brian
Gunguy05
Images: 6
Postby KCStudly » Fri Apr 25, 2014 8:10 am
Nice work! :thumbsup:
Postby absolutsnwbrdr » Wed Apr 30, 2014 10:48 am
Definitely coming together nicely!! :thumbsup:
Zach
Coming Soon...
absolutsnwbrdr
Images: 412
Postby danlott » Wed Apr 30, 2014 11:10 pm
Well got a little bit of time today to do some sanding on the joint and hopefully this weekend I will be able to put some plywood on the roof.
Dan
danlott
Images: 264
Postby Junkboy999 » Wed Apr 30, 2014 11:22 pm
She is looking great Dan.
Junkboy999
Images: 52
Postby Starseeker » Thu May 01, 2014 9:14 am
its getting there :thumbsup:
Great job!
Aaron
KF5VBV
Starseeker
Images: 10
Re: Modified 2+2 trolley top - roof plywood started -pg 11
Postby danlott » Sat May 03, 2014 7:10 pm
Got the first layer of 1/8" plywood on my trailer roof. Used construction adhesive and 1/2" staples. I will leave the staples in place. I am now starting to put on the second layer of plywood. I am using plastic strapping to staple through for the second layer, so I will be able to remove the staples once the adhesive sets up.
Dan
danlott
Images: 264
Postby Gunguy05 » Sat May 03, 2014 7:59 pm
Looking good! I bet it feels good to have that foam nice and covered up.
Great work!
Brian
Gunguy05
Images: 6
Postby danlott » Sat May 03, 2014 9:18 pm
It is nice to just be making progress. My time to work on the trailer has been very limited due to my job. I was hoping to get it ready in time for this years IRG, but I will not be able to do that. Oh well at least it is progress.
Dan
danlott
Images: 264
Postby KCStudly » Sun May 04, 2014 7:52 pm
Good things take time, and you are doing really good work, so take your time. :thumbsup:
Postby Gunguy05 » Sun May 04, 2014 7:56 pm
danlott wrote:It is nice to just be making progress. My time to work on the trailer has been very limited due to my job. I was hoping to get it ready in time for this years IRG, but I will not be able to do that. Oh well at least it is progress.
Dan
Don't feel bad, we bought our trailer Jan 17th, ALMOST have the floor complete.
You will hit a surge soon.... I can feel it!
Brian
Gunguy05
Images: 6
Postby danlott » Sun May 04, 2014 9:39 pm
Started putting on the second layer of plywood on the roof. I started out using some web strapping that I had, but was not very pleased with the results. The straping was helping to remove the staples, but not all of them. Also using the web strapping and staples did not work the best for applying pressure to help hold the plywood down.
I then decided to rip some 1 inch wide strips of 1/8" plywood scraps. The strips are actually easier to use then the web strapping. It also helps apply good even pressure and holds the plywood better. Plus romoving the strips with the staples is easier. There are also less marks from the stapler and staples in the second layer of plywood then there is with the web strapping.
Was not able to finish the second layer of roofing since I ran out of construction adhesive. It is Sunday and I live in a small town, should have bought more yesterday. Oh well should be able to finish the second layer next week and then move on to the hatch.
Dan
danlott
Images: 264
