FoamStream...
Re: FoamStream...
Postby GPW » Fri May 02, 2014 5:32 am
Bonnie , it really wasn’t intended to be pretty , just making darn sure the window is sealed ...The window is stout , made of 1/2" plexiglass... very secure (security) ... didn’t want ANY leaks (however small) spoiling that ... ;)
This morning , we’re going to pull it out the Studio and give it a little “wash” (clean off the sanding dust, we do want a CLEAN surface to start priming on ) ... Pretty day in store for us .... Great weather (fortunately ) for doing this ... :D
Re: FoamStream...
Postby bonnie » Fri May 02, 2014 6:37 am
I think the rain is finally moving out of our area. Good thing too. The back yard is making hay! Looking forward to a productive weekend, myself. :)
Remember, the turtle won. :)
bonnie
Images: 107
Re: FoamStream...
Postby GPW » Fri May 02, 2014 8:21 am
That was some Winter huh , and Spring’s started with a bang ... :frightened: Rains a lot here anyway , gotta’ work outside when we can ... :D ... and then it gets HOT!!! :o
Re: FoamStream...
Postby GPW » Fri May 02, 2014 9:42 am
Well now, a little Cleaning goes a long way ... :o :roll: :lol: Cleaned up much better than I expected ... just a couple little rust spots on the frame to attend to ... mostly on the brackets ... Once it gets a chance to dry out , we’ll pull it back inside and prime those spots with some Rustoleum primer , then a coat of red Rusto’ enamel over that ... That oughta' do it !!! . Tape off the frame with masking tape and newspaper and we’re ready to paint the cabin ... :dancing
Re: FoamStream...
Postby GPW » Fri May 02, 2014 11:24 am
Bye Bye Mr. Camo ...
Re: FoamStream...
Postby GPW » Sat May 03, 2014 9:18 am
No More Camo ... :o I Kinda’ miss it already ... but the new paint will be Much Better... :D
Re: FoamStream...
Postby tsmyth » Sat May 03, 2014 3:14 pm
How did you get the radius on the corners of "MR> CAMO" foamie? Wwhat is the radius dim?
thanks,
t
tsmyth
Images: 28
Re: FoamStream...
Postby GPW » Sat May 03, 2014 3:44 pm
T, belt sander and Big sanding block made by gluing flattened sanding belt to board ... It was messy !! :o TLAR method!!! ;) ~ 2” R
Oh , and found out (the hard way) Never drop the Gripper on a weathered HF fender ... Even if you wipe it off right away , it still stains the black fender .. :o I’ll have to paint those for sure ... :duh:
Re: FoamStream...
Postby bonnie » Sat May 03, 2014 5:05 pm
GPW wrote:T, belt sander and Big sanding block made by gluing flattened sanding belt to board ... It was messy !! :o TLAR method!!! ;) ~ 2” R
How about the red?
bonnie
Images: 107
Re: FoamStream...
Postby GPW » Sat May 03, 2014 5:24 pm
... the Red , I was Careful .. ;)
Re: FoamStream...
Postby bonnie » Sat May 03, 2014 6:03 pm
GPW wrote:... the Red , I was Careful .. ;)
:lol: :lol: Sorry, I meant I think it would add some zing to paint the fenders red like the frame. :)
bonnie
Images: 107
Re: FoamStream...
Postby GPW » Sun May 04, 2014 5:16 am
Red fenders .... That’s possible ... :thinking:
Re: FoamStream...
Postby GPW » Sun May 04, 2014 6:44 am
Got Everything primed now , and a first coat of color around the door and windows .. (the jambs) ... Just a Perfect day for painting (weather) , got my paint clothes on ( again) , and just waiting for it to get a little lighter outside ... This will be Fun !! 8)
Re: FoamStream...
Postby GPW » Sun May 04, 2014 11:08 am
Hours later we return to the scene... The first and second coat of the top color has been applied .... :D Now curing in the Sun.
Re: FoamStream...
Postby lthomas987 » Sun May 04, 2014 11:17 am
Now that it matches the house maybe you can hide it in plain sight!
Laura
Bike-Drop a Micro-Foamy Build Journal http://www.tnttt.com/viewtopic.php?f=50&t=59274
My first Superlegarra-ish Foamy build http://www.tnttt.com/viewtopic.php?f=55&t=59049
lthomas987
Images: 204
