Jdhiker wrote:The grey RV tape is like 3/4 wide. Would you put it side by side to lap over the edge a little for the roof trim to seal the side wall edge too?
DMcCam wrote:Jdhiker wrote:The grey RV tape is like 3/4 wide. Would you put it side by side to lap over the edge a little for the roof trim to seal the side wall edge too?
Hi Jim,
The butyl RV tape will squish down a lot. I put two layers side by side overlapping the roof edge then put the trim over it and screwed it down. It seeped out under the roof edge trim all summer on the sides. I'd take a plastic edge tool for cleaning grout and clean it up periodically. The stuff expands with heat quite a bit. It was probably overkill but I know I've got a good seal.
All the Best,
Dave
