dodgedartgt wrote:Andy,
Consider taking the assembly to a muffler shop and having them "tweak" the forward bend in the trailing arm on their bender to bring the wheel face and pivot bushing into line with each other. I doubt it would take much effort at all. When I worked at the "suspension" place years ago, we used an exhaust pipe bender with custom dies to bend up our sway bars.
Or, take advantage of the discrepancy and cut the two bends out and rebuild the trailing arm as a straight piece. That way the pivot point will be much closer to the centerline of the trailer.
Mike in FL
Ron Dickey wrote:most of the one wheels I have seen have been shorter.
http://www.google.com/search?q=one+whee ... 89&bih=899
Hope you get it balanced right. most that have any weight have 2 connectors to the pull unit.
Maybe you will start a new idea in the one wheel world.
Good luck
looking forward to more pictures.
rowerwet wrote:my dexter trailer axle is not level, it is curved, I looked into flipping it so I could make the tear ride lower, but I would have needed to get the axle perches cut off and welded on the other side. This does mean the tires with no load are not plumb, but from what I've read this was done on purpose, as the load increases the axle takes on the correct shape. Most likely this is the same situation, and since cars are built to go around corners the rear tires are normally not vertical. Look at a late model Ford Focus, the rear tires tilt in toward the top enough to see easily, it is all about carving through the corners.
Gpike wrote:Alignment...
Something like this might help.
http://www.andysautosport.com/camber_sh ... abbit.html
Even with the rubber bushings, it should return to center, but these may be a good way to adjust the tracking.
Great build by the way, you have some great and interesting ideas.
WeirdDogGuy wrote:But I worked a trade today for a weird car that has live hydraulics. It can kneel. It's a 1966 Citroen Safari Break.
angib wrote:WeirdDogGuy wrote:But I worked a trade today for a weird car that has live hydraulics. It can kneel. It's a 1966 Citroen Safari Break.
Getting into Citroen hydraulics is a bit like going over to the dark side - you are inclined not to come back.
But they are neat. The best Citroen party trick is to use a block of wood to change a wheel - lift car right up, put block next to relevant wheel, let rest of car right down and the wheel comes off the ground.
Here's someone doing it the fancy way with a gen-u-ine jack stand. http://youtu.be/KSabTiFpIzY
