Matthewp's MuTTT (Multiple Terrain Tactical Teardrop).
Postby matthewp » Fri May 16, 2014 7:56 pm
Here's the rear hatch frame pieces cut out. It's a 2 X 4 up top with 1/2" plywood for the ribs
All screwed and glued together.
matthewp
Re: Matthewp's MuTTT (Multiple Terrain Tactical Teardrop).
Postby dustboy » Fri May 16, 2014 11:50 pm
Maybe I missed it, but where did you find that nifty water level gauge? I've looked everywhere.
Great build!
dustboy
Images: 10
Postby matthewp » Sat May 17, 2014 7:32 am
dustboy wrote:Maybe I missed it, but where did you find that nifty water level gauge? I've looked everywhere.
Great build!
Here is the link to the gauge, I also bought the sending unit from the same place:
http://usmarineproducts.com/osc/product ... 17e53381db
matthewp
Postby matthewp » Mon May 19, 2014 11:33 am
This weekend, the roof sheeting was started, and some of the related needs.
The awning and mounts test-installed.
The first layer of 5mm is on.
The rear hatch was squared up and ready for skinning (I skinned the inside ready to test the seal but don't have pics of that).
matthewp
Postby matthewp » Mon May 19, 2014 11:37 am
I also had to finish the side table storage under the kitchen area. This will house a slide in storage for two tables that will mount on each side of the trailer at the back.
matthewp
Postby RandyG » Mon May 19, 2014 3:51 pm
That is serious lip on your hatch, no water getting in there. :thumbsup:
Randy
RandyG
Images: 115
Postby matthewp » Mon Jun 02, 2014 9:56 am
Nothing photo-worthy this weekend, unless you enjoy photos of endless hours of mind-numbing sanding and epoxying (... Then you need a therapist, not a photo thread!). The body and hatch are now covered with 4 coats of CPES. I hope to have the fiberglass body filler on and sanded by the end of the week (More sanding... Woo hoo! :eek:). Then, hopefully, next weekend we'll be priming and painting.
matthewp
Postby matthewp » Tue Jun 24, 2014 8:44 am
(Deleted)
matthewp
Postby matthewp » Thu Jun 26, 2014 6:34 pm
It's been a busy weekend, but I'm getting somewhere! I hope to have the exterior finished next weekend (Sorry the previous photo didn't show up!).
matthewp
Postby drewh1 » Mon Jun 30, 2014 7:00 pm
yeah man - looks awesome!
"If only I knew what I know now when I started . . ."
My Build Journal http://www.tnttt.com/viewtopic.php?f=50&t=56916
drewh1
Images: 7
Postby matthewp » Mon Jun 30, 2014 7:19 pm
Ok. So. She's a little fat! According to the scale, 1780lbs. fat! That's without 23 gallons of water, two batteries and no galley! I'm expecting a total weight around 2300lbs., which is at the top of my weight plans. At least the outside is finished!
matthewp
Postby matthewp » Mon Jun 30, 2014 7:22 pm
matthewp
Postby matthewp » Sun Jul 13, 2014 4:14 pm
Look what followed me home yesterday...
matthewp
Postby matthewp » Sun Jul 13, 2014 4:16 pm
The weather tried its best to keep me from working but I did get the lower kitchen area framed.
I'm currently completely on hold with the sleeper area as I have found a major water leak in the frame of the front window (I figured a $20 eBay window could be hit or miss). A new replacement window is on its way.
matthewp
Postby S. Heisley » Sun Jul 13, 2014 6:45 pm
matthewp wrote:The weather tried its best to keep me from working but I did get the lower kitchen area framed.
Sorry to hear of the window leak. You'll get that fixed in a jiffy. Better to find it now than after you're all done!
