kudzu wrote:
What makes the Pelican worth $325 vs the Xtreme's $35? Just curious.
OverTheTopCargoTrailer wrote:Amazing that the Coleman held up so well - best bang for the buck.
Works great for your corona beer - if you don't wanna cool them in the stream.
If your out Glamping then the IRP cooler would be your #1 choice to keep those rib-eyes fresh.
http://www.shopperschoice.com/item_item_2615210.html
OverTheTopCargoTrailer wrote:Woooooo Doggie
I'll see your 50 and raise you 13 quarts,![]()
got mine 2 years ago for $800 or $850 max ?
I also have been very happy with it , when I set mine at 26 deg F the frozen stuff stays frozen on the sides
And the other stuff stays unfrozen on top. It uses between 200 winter to 600 summer watts depending on ext temp
For those who wanna know soda because of sugar won't freeze till its around 26 deg.
They want $1037 now At your link Less 10% I guess ?
http://trdparts4u.toyotaofdallas.com/scripts/prodView.asp?idproduct=-8723
OverTheTopCargoTrailer wrote:Hey I'm with you brother
The 37 & 50 share same compressor
The 63 & 80 share same compressor
Cheers Jerry
tnriverluver wrote:I've had 3 Coleman Extremes since 2007 and they have gotten a lot of hard use. Still work as good as new. The larger of the 3 seems to keep thing cold the longest, but even in out 90 degree + summer weather they will all keep things cold for 4 days before I have to buy more ice. The main trick is to put everything in good and cold to begin with.
