How do you stow/hide your potties?
Re: How do you stow/hide your potties?
Postby S. Heisley » Mon May 19, 2014 9:05 pm
Well done, Cornfused. Keep up the good work! :thumbsup: :applause:
Postby lrrowe » Tue May 20, 2014 7:42 am
Confused,
Now there you go, grabbing the ideas right out of my head. Good work.
This is almost exactly the idea I was going to use, except I was to have mine slide into the shower area when used and back out for storage. There would be minor details to work out, certainly doable, and you for sure have confirmed that. And with your height, you sure do take care of the ADA issues, the ones I must certainly do appreciate.
Bob
Bob
lrrowe
Images: 439
Postby grantstew8 » Tue May 20, 2014 8:55 am
Initially I thought it was a joke given the other images I've seen with a boyo sitting on it with a fishing rod in one hand and a revolver in the other.
The UK towhitches are different to the US, where it's not removable, just bolted on. With some clever welding and a windbreak to give privacy, it could be made to work so the potty is never inside the TD.
grantstew8
Images: 77
