Hello,
I've been lurking and learning from the people in this forum. I think I am ready to take on designing my first TTT.
First, some requirements for my TTT:
- I have no metal skills/experience, so I prefer a simple unmodified HF trailer (4x8).
- Solo camping most of the time, perhaps room for two in the future.
- No galley needed, I don't cook.
- I want to have a configurable internal space so I can rearrange (eg. all sleeping area, 1/2 sleeping with small desk, etc).
- Prefer insulated walls and roof to keep sound down.
- TTT needs to be garageable.
So I've decided on a simple design.
- Stick built 4'x8'x4' box.
- 1x2 poplar for walls.
- 3/4" insulation in walls.
- FRP exterior skin (may paint with UV exterior paint).
- 1/8" ply interior skin.
- 2x2 poplar around the base of the wall where it meets the floor.
- 1/2" plywood floor.
- Removable roof built from 3/4" EPS foam board, completely covered in canvas and TBII (inside and outside).
- Roof secured to top of 4'x8'x4' box using screws and tee nuts. Small 1/4" plywood pieces will be glued into the foam for tee nuts to secure to.
The roof can be removed when the trailer is moved in/out of the garage. It can even be stored on the side of the trailer, if there's not enough height in the garage. The roof is secured to the top of the 4'x8'x4' box while in motion and camping. I hope this makes sense.
Questions:
- How heavy is the foam roof going to be? Can one person lift it slightly and slide it to the side (as shown below)?
- Is the 4x8x4 box going to be stable enough without roof spars?
- In general, is this design doable? Anything glaringly wrong? Please critique.
- Removable Top - Side.jpg (163.18 KiB) Viewed 1709 times
- Removable Top - Back.jpg (167.37 KiB) Viewed 1709 times
- Removable Top - Inside 2.jpg (251.7 KiB) Viewed 1705 times
