help needed removing weatherstripping adhesive
Postby BillZ » Sat May 31, 2014 8:12 am
I need to replace the door weatherstripping and am having a heck of a time getting the old adhesive off. I started to use Goo Gone but saw that it removes varnish. The doors are varnished (Spar Urethane)wood and indeed the Goo Gone was softening the finish so I stopped immediately.
I haven't been able to find an adhesive remover that won't damage the varnish. It also looks like some silicone may have been used for extra adhesion but I am not certain yet.
Any help is appreciated!
BillZ
Re: help needed removing weatherstripping adhesive
Postby Wanna Be » Sat May 31, 2014 8:20 am
You might want to try " Zippo" lighter fluid.
It works, and I didn't notice any varnish removal.
Wanna Be
This nation will remain the land of the free only so long as it is the home of the brave.
~Elmer Davis
"Well, if you can't believe what you read in a comic book, what can you believe?" ~ Bullwinkle J. Moose
Also I am a professional spelling butcher.. I don't carry a dictionary and my spell check is broke!!
Wanna Be
Postby BillZ » Sat May 31, 2014 8:34 am
Thanks for the tip.
I was doing more research and found WD-40 was mentioned to work. Since it can remove paint I am guessing it's probably not good for varnish.
Another article mentioned denatured alcohol would remove silicone without harming varnished surfaces. I'll have to try that also.
BillZ
Postby teamredjeep » Sat May 31, 2014 5:17 pm
teamredjeep
Postby BillZ » Sat May 31, 2014 8:38 pm
Thanks for the reply. I just spent about 6 hours painstakingly scraping with a plastic scraper, softening with a hair dryer, a little goo gone, and denatured alcohol. There was a lot of silicone to remove. Ugh! I am beat but I got it off and the new on. Hopefully the doors won't leak now for several seasons.
BillZ
