Went to the orange box store.. picked up another sheet of 2 inch ( needed alittle more anyway)..and a few sheets of what I call lauan, and they call floor sheathing. Some of that stuff is prettier then oak ply.
Came home and took a hard look at the mass of broken pieces. Alot of the roof pieces is going to be able to be jigsawed back into one sheet. The wall break where it sheered off also encompassed the door. Decided I just dont trust the sheered off edge so.. Cut it down and straight, cut a notch in the wall behind the door to make a ledge and inserted a new piece of foam, from nose to door.
Got the roof spars that I had been waiting to install, in place. And I decided to just give the roof alittle more oomph, as well as give myself a nice pretty ceiling by using the sheathing under the foam for the roof. Its stronger, still fairly light and with all the seams staggered ( crooked, jigsawed and skewed). Its Pretty wood too. might just have to leave it visable with some varnish.
Got most the front bulk head in.. shelf top is big enough to hold the DVD tv radio thing, the doxies bed and has 3 storage compartments below.. that I discovered are REALLY water tight.. they had 6 inches of water in them. had to punch a hole to let it all out.
ignore the construction mess
On wards and up wards.. tomorrow the foam goes ontop of the wooden roof.. and I begin sanding again..
* in here, some of my dreams become realities, and some of my realities become dreams* - Willy Wonka
