This could easily work for your inside door handle, as well.
KCStudly wrote:For your light switches and door pull, you could do what I did and make a decorative trim piece. I had the same problem; by the time the wire connectors were on the backs of the switches they were deeper than the walls were thick. Call it a rosette or riser. No need to make the whole door or door flange thicker. I made the switch plates, too.
KCStudly wrote:The metal is 16 gauge 304 SS with a #4 brushed finish (16 gauge in stainless is .063 thk).
Yes, I scored the outline with a razor knife and hand chiseled the recesses so the metal is flush mounted. Soft maple from ho-de-po, Minwax "Natural" oil finish, with polyurethane.
RandyG wrote:Not sure but I think most of the stuff you have left will only make the tongue heavier. What's the weight limit on your TV? Maybe once done try to load the heavy camping gear in the galley, got any cast iron?
RandyG wrote:Wow, that's alot to do! Is there any way you could just move the whole cabin back 6"? Would that be easier? Just hate for you to get set back like this.
absolutsnwbrdr wrote:I forget if I mentioned it in this thread or another, but if you're concerned about weighing down the Outback, you might look into replacing your stock springs with a pair of Rallitek Overload Springs..... http://www.rallitek.com/RallITEK-Overlo ... acy/p-4610
On my 05 Outback I had the Overload Springs and also 1-1/4" body lift spacers (from Subtle Solutions) on top of the strut assemblies. Jacked the car up a little and was quite a bit stiffer. Great for towing!
tony.latham wrote:I'm very impressed with your build. How are you going to tell your second born, that you've written into your final will & testament that his older sibling gets the trailer? That thing's going to be a multi-generation heirloom.
I read your post on your tongue weight. I think teardrop builders need to keep a bottle of Tylenol handy. You'll figure it out.
I'm surprised you've kept the trailer weight below a thousand pounds. (My 5x10 weights 1380) How long is yours?
