should one have a fuse in basic trailer to car wiring
Anything electric, AC or DC
Postby Ron Dickey » Mon Jun 12, 2006 10:57 pm
I bought lights that came wires but I see no fuse :(
do I need one or two?
or should there be one before the plug from the pull unit? :thinking:
173882......173887
Ron Dickey
Images: 787
Postby madjack » Mon Jun 12, 2006 11:02 pm
Ron, you could do that but you would be one of the only ones to do so...those lights are fused at you cars fuse block...but if you wanna, it is yours afterall...
madjack 8)
Postby Miriam C. » Mon Jun 12, 2006 11:57 pm
JMMHO
No. Your already fused at the tow vehicle and I personally don't want my wires spliced anymore than needed. Remember, every splice is a place waiting to come undone. :? Plan where your clearance lights go too.
Now wire from the aux. battery to the tear will have a separate fuse box.
Miriam
Postby Leon » Tue Jun 13, 2006 2:02 am
I put a separate fuse in the trailer light circuit that is less than the running light fuse on the car. that way if the trailer has a problem it blows the trailer fuse and I only loose the trailer lights instead of the entire car. It happened once when I had to tow a friend's trailer and one of his wires was touching ground. On my S-10, there is a provision to take the trailer signals before the truck's fuses, so separate fuses are easy to add at that point and isolate the trailer from the rest of the tow vehicle.
Leon
Images: 21
Re:
Postby Ron Dickey » Sun Jun 22, 2014 1:05 am
Leon wrote:I put a separate fuse in the trailer light circuit that is less than the running light fuse on the car. that way if the trailer has a problem it blows the trailer fuse and I only loose the trailer lights instead of the entire car. It happened once when I had to tow a friend's trailer and one of his wires was touching ground. On my S-10, there is a provision to take the trailer signals before the truck's fuses, so separate fuses are easy to add at that point and isolate the trailer from the rest of the tow vehicle.
I am thinking putting a box in that would plug after the car and before the trailer. it will have male and female trailer plugs.
what size fuse did you use in the trailer.
173882......173887
Ron Dickey
Images: 787
Re: should one have a fuse in basic trailer to car wiring
Postby Dale M. » Sun Jun 22, 2014 9:00 am
I'm thinking its added complexity and another place to cause a problem and you don't need it....
Dale
Dale M.
Images: 18
Postby Esteban » Sun Jun 22, 2014 1:22 pm
Ron, I am putting a junction box under my trailer. Auto parts stores probably sell them.
Steve - SLO, CA
Esteban
Images: 15
Postby working on it » Sun Jun 22, 2014 7:43 pm
Dale M. wrote:I'm thinking its added complexity and another place to cause a problem and you don't need it....
Dale
However, if it simplifies the wiring and keeps it tidy, then it my be a boon...Dale advised me to try using one, previously, in an earlier thread http://www.tnttt.com/viewtopic.php?f=21&t=58985&hilit=spectro&start=45#p1072104(suggested also, here, by Esteban). I used this one: http://www.etrailer.com/Accessories-and-Parts/Spectro/38656.html
Spectro 7-way.jpg (53.39 KiB) Viewed 695 times
It was a life-saver.
173193172890148599
working on it
Images: 457
Return to Electrical Secrets
