Need power converter
Anything electric, AC or DC
Postby lee » Thu Oct 14, 2004 2:50 pm
Where can I get a power converter AC to DC? I want a 15 to 30 amps. We want to put it in the Tear Drop we are building. We also need any information on how to wire the Tear Drop. Thanks
lee
Inverter
Postby lawndoc » Thu Oct 14, 2004 6:13 pm
Hey if you can find one let me know. My plan is to wire 12VDC and have 120vac outlets for microwaves and such, but would be nice to have inverter. Wire the 120 vac directly to a marine battery charger to keep the battery charged and still be able to run 120vac at same time if i want too.
lawndoc
Postby Eric Adams » Thu Oct 14, 2004 7:57 pm
Radio shack caries them. The more amps, the higher the cost. I think they are called "converters". 110v to 12v are converters, 12v to 110v are called inverters. :D
Eric Adams
Postby Chuck Craven » Thu Oct 14, 2004 8:24 pm
What do you mean by 15 to 30 amps. Is that 15 to 30 amps on the 120 volt AC side or is that 15 to 30 amps on the 12 volt side? If you are looking for a battery emulator try some of the electronic supply houses. Also try amateur radio supply houses, power supplies used for 12-volt ham radios. They sell some up to 75-amp output or more. If you know of someone in to electronics there are ways to use an old computer power supply to get up to 20 amps at 12-volts. But you need to know what you are doing else “buss, smoke, fire or worst” will be the results. That is not the excitement one is looking for when camping. :shock:
:roll: Chuck
Chuck a new td builder
Chuck Craven
Images: 62
About converter
Postby lee » Fri Oct 15, 2004 8:26 pm
All I know is in our pop-up camper we have a central power pack -power converter. We wanted the Tear Drop to be wired like the pop-up. I think it is a 15 amps. You can use a l2 v. battery to run the lights inside. We always conects to the electric source at the camp grounds. The lights works inside because of the converter. We wanted this system because it works the way we need it to work. If we need to use the 12 v. battery we can, but its simple this way. I hope this makes it easier to understand. Thanks
lee
Postby Chuck Craven » Fri Oct 15, 2004 9:23 pm
Are the lights 12volt or 120volt?
Chuck Craven
Images: 62
Postby BoilermakerFan » Fri Oct 15, 2004 11:31 pm
The lights would be 12VDC in lee's case since they have to run ac power through the converter or can run off battery power.
BoilermakerFan
Postby mikeschn » Sat Oct 16, 2004 6:27 am
Oh I know what he's looking for. He's looking for a power converter.
I used a Pyramid Power Converter that I got at JC Whitney. I have a toggle switch that switches between the power converter and 12V battery...
http://www.jcwhitney.com/autoparts/Prod ... 46/c-10107
Postby Eric Adams » Sat Oct 16, 2004 6:58 am
mikeschn wrote:Oh I know what he's looking for. He's looking for a power converter.
Which model is that? I don't see it listed and they show the same pic for every model. :(
Eric Adams
Postby mikeschn » Sat Oct 16, 2004 7:04 am
We bought our second power supply (for the second teardrop) at Mobile Emotions. They had a better price than JC Whitney, and they had the correct photos for each power supply.
http://shop.store.yahoo.com/mobile-emot ... 4pows.html
Postby lee » Sat Oct 16, 2004 12:51 pm
Mike:
Thanks--- We will need to convert the ac for about 4 or 5 lights. Do you think this will take care of these? I am a she. I do all the gathering of information and my husband (Angel) does all the work. I know our names seems backward. When we get the sides up I will try to send a picture.
lee
Postby mikeschn » Sat Oct 16, 2004 6:14 pm
Hey Lee,
That's more than enough power for a few lights! You'll be able to run a few lights, a 12V tv and dvd player, lights in the galley, and even your mattress warmer if you so desire... :wink:
P.S. Oh yes, you can run the car stero, and the 12v thermoelectric cooler too! :shock:
Postby BoilermakerFan » Sat Oct 16, 2004 9:31 pm
Thermoelectric cooler? Mike, please post a link...
BoilermakerFan
Postby mikeschn » Sun Oct 17, 2004 3:56 am
Powr supply
Postby Chuck Craven » Mon Oct 18, 2004 3:53 pm
That is just a 12-power supply or better known as a battery emulator.
Just a note do not use it to charge a battery unless you watch it very close, as a power supply will over charge a battery and shorten it’s life.
Power supplies do not know when to stop/slow charge a battery.
Chuck
Chuck Craven
Images: 62
Return to Electrical Secrets
