Started Today
Re: Started Today
Postby mrwall1 » Sun May 18, 2014 2:45 pm
I am using screws and liquid nails
my Old Teardrop build journal
viewtopic.php?f=50&t=59792
My New 7x16 Continental V Nose Build
viewtopic.php?f=42&t=67734
My Photobucket Link to 7x16 V nose build
http://s20.photobucket.com/user/mrwall/ ... %20Trailer
Mike
mrwall1
Re: Started Today
Postby mrwall1 » Sun May 18, 2014 8:54 pm
One more small step! I insulated the bottom with the dense board foam, then I sprayed the spray foam around the edges. The spray looks crappy, but I can trim tomorrow...maybe tomorrow I can start on the sides!
Mike
mrwall1
Re: Started Today
Postby mrwall1 » Wed May 21, 2014 7:51 pm
I worked on the sides and squaring it up today!! I need to get some more 1x2's to finish the framing... everything seems to be going together better then I thought!! I also ordered the Trailer frame today.. I found one at Home Depot online only that has 13" Wheels.. and will hold 2000 pounds.
Mike
mrwall1
Re: Started Today
Postby Starseeker » Thu May 22, 2014 12:27 pm
Looks like you are moving along. Keep up the good work.
Aaron
KF5VBV
Starseeker
Images: 10
Re: Started Today
Postby mrwall1 » Sat May 24, 2014 5:50 pm
Good day today!! finished the framing.. Finished cutting the flooring and waterproofing, will screw in tomorrow! and added some drawers to the Kitchen area!
Mike
mrwall1
Re: Started Today
Postby mrwall1 » Sun May 25, 2014 10:23 pm
My wife got the flooring in today! I will start framing the sides tomorrow... hopefully the Doors will come this week! we bought a package of Knotty Pine today, to see if we want to use it on the interior...
I also took some scrap lumber and built a Kayak/Paddle Board Rack today.. saw it on instructables
Mike
mrwall1
Re: Started Today
Postby mrwall1 » Fri May 30, 2014 5:35 pm
Yay!! Trailer showed up today!! I am going to sand the bottom and spray another coat of paint on it before I assemble it... try to delay the rust!!
Huge Pallet Board!! Glad I had help to unload it from the freight truck!!
Mike
mrwall1
Re: Started Today
Postby mrwall1 » Sat May 31, 2014 11:41 pm
Trailer put together... Bummer though, the side rails are 11 inches high... the one at the store was 8 inches high, so I assumed that the online one was the same... so now I need to attach the box a different way... probably still use the corner angles... and now... I really wish I would of not built the basement.....oh well learn as you go...
Mike
mrwall1
Re: Started Today
Postby mrwall1 » Mon Jun 16, 2014 8:00 pm
Well it has been a while, I finally got back on it this weekend, The Doors came in, The Hinge, and the Fantastic Fan, so I cut out the door holes, and now I can finish the interior, so here are a few pics of the progress!
Kitchen Area
Fan
Mike
mrwall1
Re: Started Today
Postby SLUG36 » Tue Jun 17, 2014 11:48 am
THE BEAD BOARD LOOKS GREAT. I used Cedar Bead board on the ceiling in my bathroom. I wish I could afford to do a whole room.
Making big pieces of wood into the wrong size..... for over 30 years....
SLUG36
Images: 137
Re: Started Today
Postby mrwall1 » Sat Jun 21, 2014 11:48 pm
Thanks! I accidently bought a package of Cedar I think i would use the cedar instead, the boards are a little better quality!!
well, I got a lot done this week, finished all the interior walls, ( i got a little sloppy at the end, cutting the boards, glad i will be using trim boards!!) Just have the trim left to put up, started the wiring, prepped and primed the 2 side walls, also bought a tongue jack with a wheel on it..
Hope to do some more finish work tomorrow on the side walls, get some trim up, start insulating the roof, build the shelf, and get the fantastic fan set in place!!
thanks for looking!
Mike
mrwall1
Re: Started Today
Postby mrwall1 » Sun Jun 22, 2014 7:35 pm
I finished Painting the sides today (not the final coat or color) but good for now, it took four of us to lift it up and put it on the Trailer... The Online trailer we ordered is 3/4 inch narrower, so I had to remove the fenders from the trailer, so the box would fit. but I think I will probably leave it on the trailer permanent.
Mike
mrwall1
Re: Started Today
Postby SLUG36 » Mon Jun 23, 2014 6:44 am
looking good. you are working fast. I didnt do much of ant thing on my build this weekend. but, its hard to be motivated when the temperature is in the upper 90's and high humidity.
SLUG36
Images: 137
Re: Started Today
Postby mrwall1 » Sat Jun 28, 2014 8:35 pm
After a long week of doing nothing... I got the roof on and the electrical done except for hooking up to the outlets. I had to piece together the roof, then I put some heavy duty tape and epoxy over the seams... hopefully it wont mound too bad... then eventually I will figure out what to put on for the top layer.. either aluminum or fiberglass....
Mike
mrwall1
Re: Started Today
Postby mrwall1 » Sat Jun 28, 2014 11:28 pm
oh... I like this!! might do this... I will water proof or tar paper the roof first...
Mike
mrwall1
