by be_a_jayhawk » Fri Aug 22, 2014 10:12 pm
I posted this in the foam tools thread but in case you missed it. I bought this hot wire cutter fir $35 and it worked great cutting rough curves that I am bow sanding down. The handle comes out of the base which is mainly how I used it and the wire is 5 inches wide so big enough for two foam boards sandwiched together to make the curves.
- Attachments
- uploadfromtaptalk1408763391865.jpg (32.69 KiB) Viewed 2529 times
- uploadfromtaptalk1408763384195.jpg (32.75 KiB) Viewed 2529 times
