oakinteriors1 wrote:WOW been a while since I'v been on this forum, looks really nice....I'm thinking of staining mine also...
I've found when spraying Helmsmans Spar urethane it's crucial to have good light to see if you get it wet enough yet not run..., not wet enough, you get orange peel and, unlike lacquer which I have sprayed for decades, urethane is a bear to sand out smooth...Best to have an orbital sander for that...
My woody I plan to epoxy over the raw wood, then the spar urethane, like I do cedar kayaks....
I have already found that sanding the urethane is a pain. Great upper body workout. I think mine looks streaky because of the application, or so I have been told. So, after we are done I will sand it down again and then stay on a thin layer. I actually have checked back on your build and noticed there weren't any updates. Is it finished? I will have to check out your other builds. You do some great work!
I picked my stain before anything else in my teardrop build. Before I knew much about wood. It ended up working out pretty well for me, but I didn't always get exactly what I wanted. Living and learning and loving how much knowledge I have gained. Thanks for your input and I hope to see some updates from you as well!
