New member and new build in MS
Postby willfish4fud » Sat Jun 28, 2014 9:21 pm
I just picked up a new Pace 6x10 and starting to outfit. I am a sporadically employed fly fishing guide and intend to travel and fish for a year or two or whatever. My hope is to have it wired, insulated and AC by the end of the week. Ill be heading to FL on the shakedown trip for some tarpon fishing. I plan to keep systems simple for now and use it and see what I need/don't need. Ive seen some great rigs on here and look forward to participating.
So far I have tried to post and I keep getting logged out so hopefully this time it works.
willfish4fud
Re: New member and new build in MS
Postby hankaye » Sat Jun 28, 2014 9:29 pm
willfish4fud, Howdy;
Welcome aboard! Sounds like the beginnings of a plan. Looking forward to
seeing what you come up with.
hank
hankaye
Postby willfish4fud » Sat Jun 28, 2014 9:31 pm
Ive tried to post a pic but every time I try to post anything I have to re- sign in for every post...Ive been on here 5 minutes and had to sign in 8 times...help anyone?
willfish4fud
Postby AZ_Desert_Rat » Wed Jul 02, 2014 12:10 am
Welcome aboard willfish4fud,
Sounds like you going to have some fun ... 1st building a CT Conversion and then getting to use it. One thing for certain, you sound like you have an immediate build in mind and are looking ahead for the inevitable changes and tweaks that make the trailer personal!
Good Luck and I hope you have as much fun as I am ... 8)
I have not had the issues you are having and can suggest that you keep your pics small as Amin suggests and if you continue to experience problems, contact the Admin ... they are great!! :applause:
Happy Camping & Building,
John (JC)
The Arizona Desert Rat 6x10' Cargo Conversion
The FunFinder a 19' Toy Hauler
An AZ Desert Transplant
Gallery: gallery/album.php?album_id=3168
AZ_Desert_Rat
Images: 55
Postby willfish4fud » Thu Jul 03, 2014 11:47 pm
This week i removed plywood and insulated with 3/4 blue foam board in sides and 1" in roof. I then wrapped sides in foil bubble wrap insulation. I will do bubble wrap in roof tomorrow. I also installed exterior lights and roughed in all 12 volt wiring. Has been hot and miserable here so this stage hasnt been fun. But the interior build out is coming up n am looking forward to that.
willfish4fud
Postby willfish4fud » Fri Jul 04, 2014 12:13 am
6x10 on the way home
6x10 pace
pace 6x10.png (131 KiB) Viewed 2520 times
willfish4fud
Postby willfish4fud » Fri Jul 04, 2014 12:25 am
Blue foam board and foil bubble wrap are in and ply is back on
pace trlr insulation in.png (195.4 KiB) Viewed 2518 times
willfish4fud
Postby Woodbutcher » Fri Jul 04, 2014 8:39 am
Looks like a fun project. You should be able to make that into a nice home!
Woodbutcher
Postby OverTheTopCargoTrailer » Fri Jul 04, 2014 10:09 am
Welcome aboard
I'm glad to see that the Dow Blue board is finally catching on here,
It's hands down number 1 quality vs the pink or white.
Don't forget to put some on the floor & doors too
Cheers OTTCT
:thumbsup: :thumbsup: :thumbsup:
Postby willfish4fud » Sat Jul 12, 2014 10:58 pm
I live in the woods and internet has been hard to come by lately. I finished insulating and then built the electrical panel on a piece of 3/4 ply in my living room. I have a 12v system including a battery switch that allows switching between two batteries or paralleling them. I ran a separate line from the Honda 2000 generator to a dedicated outlet (bottom one). Then shore power runs through breaker box and has one dedicated circuit for 5,000 btu AC and another for miscellaneous. All lights are 12v LED. Air cond can be run by shore power or generator simply by unplugging from one and plugging into the other. Solar panels are not installed yet but are a future add.
pace 6x10 elec panel layout.png (213.65 KiB) Viewed 2289 times
willfish4fud
Postby willfish4fud » Sat Jul 12, 2014 11:01 pm
heres panel installed on interior front wall. also made and installed a rack for 2 batteries and generator
pace 6x10 gen rack.png (169.82 KiB) Viewed 2280 times
pace 6x10 elec panel 2.png (198.2 KiB) Viewed 2280 times
willfish4fud
Postby willfish4fud » Sat Jul 12, 2014 11:06 pm
Also got part of flyrod racks made n installed. These will be closed in when ceiling is done and will hide tubes. Also serves as a chase for running wires front to rear
pace 6x10 rod racks.png (240.89 KiB) Viewed 2279 times
willfish4fud
Postby willfish4fud » Wed Jul 16, 2014 9:50 pm
cutout for AC is done and shelf made of starboard installed
pace 6x10 ac1.png (235.37 KiB) Viewed 2160 times
willfish4fud
Postby printer88 » Sun Jul 20, 2014 10:12 am
Looks freakin fantastic bro. Great job so far :D
"When all is said and done....a lot more will be said than done."
printer88
Postby willfish4fud » Sun Jul 20, 2014 12:05 pm
A friend gave me some laminate flooring...went in very easy once I got the hang of it
pace 6x10 flooring install.png (247.11 KiB) Viewed 2031 times
willfish4fud
