Gasket on windows
Gasket on windows
Postby AZKayaker » Tue Jul 08, 2014 10:05 am
I just picked up a 14x16" window for my door from VinTek. It came with a gasket glued to the outside flange. Would you guys also seal this with a putty strip, caulk or just use as-is?
See my 5x9 SquareDrop CT conversion build, trip pics and more
gallery/album.php?album_id=3552
AZKayaker
Images: 38
Re: Gasket on windows
Postby cheri832 » Tue Jul 08, 2014 1:46 pm
I bought my doors from VinTek and they also came with gasket mounted on the outside flange. I called Frank and asked him if I needed the butyl tape or anything else... His answer was nothing additional needed. When you screw the mounting ring to the window or door, the pressure on the gasket makes a waterproof seal.
Hope this helps.
Cheri
Cheri
cheri832
Images: 15
