New member and new build in MS
Re: New member and new build in MS
Postby willfish4fud » Sun Jul 20, 2014 12:06 pm
printer88 wrote:Looks freakin fantastic bro. Great job so far :D
Thanks...lots of work but coming together so far
willfish4fud
Postby willfish4fud » Sun Jul 20, 2014 12:12 pm
Wasn't going to do walls just yet but new floors made walls look pretty bad. Primed bead board paneling will probably be painted white
pace 6x10 beadboard.png (243.77 KiB) Viewed 1346 times
willfish4fud
Postby willfish4fud » Sun Jul 20, 2014 12:17 pm
hankaye wrote:willfish4fud, Howdy;
Welcome aboard! Sounds like the beginnings of a plan. Looking forward to
seeing what you come up with.
hank
Thanks for the welcome.
willfish4fud
Postby willfish4fud » Sun Jul 20, 2014 12:19 pm
AZ_Desert_Rat wrote:Welcome aboard willfish4fud,
Sounds like you going to have some fun ... 1st building a CT Conversion and then getting to use it. One thing for certain, you sound like you have an immediate build in mind and are looking ahead for the inevitable changes and tweaks that make the trailer personal!
Good Luck and I hope you have as much fun as I am ... 8)
I have not had the issues you are having and can suggest that you keep your pics small as Amin suggests and if you continue to experience problems, contact the Admin ... they are great!! :applause:
Thanks for the welcome. I am def looking forward to a road trip with CT soon
willfish4fud
Postby willfish4fud » Sun Jul 20, 2014 12:20 pm
OverTheTopCargoTrailer wrote:Welcome aboard
I'm glad to see that the Dow Blue board is finally catching on here,
It's hands down number 1 quality vs the pink or white.
Don't forget to put some on the floor & doors too
Cheers OTTCT
:thumbsup: :thumbsup: :thumbsup:
Thanks
willfish4fud
Postby willfish4fud » Mon Jul 21, 2014 11:33 pm
Not the best of days as I had to remove some paneling to reset the plywood underneath so my trim would fit. Air compressor took a dump so I went old school with paneling nails and hammer. That sucked... a lot. Not a fan of the V Nose that slants down as far as ceiling and trim work. Wouldn't buy that feature in the future. Did get paneling fixed, ceiling installed and part of trim work done.
pace 6x10 ceiling install.png (244.67 KiB) Viewed 1292 times
willfish4fud
Postby bc toys » Tue Jul 22, 2014 7:34 am
:thumbsup: you are doing a great job on this build
bc toys
Images: 42
Postby willfish4fud » Tue Jul 22, 2014 8:17 am
bc toys wrote::thumbsup: you are doing a great job on this build
thank you
willfish4fud
Postby willfish4fud » Tue Jul 22, 2014 8:43 pm
Majority of trim work is finished. TV mount and a few pieces to complete rod racks should do it. I have another cabinet I may add later. Im undecided on countertop as of yet but I plan to have it span cabinets but only come out 14-15" so as to not be in the way of entry door. II am planning a folding fly tying desk and hanging shelves from Cabelas. Am undecided on bed but considering futon with memory foam added or just standard mattress. Should be wrapped up and on the road after this week.
rod racks boxed in
pace 6x10 interior rod rack.png (215.2 KiB) Viewed 1239 times
pace 6x10 interior 2.png (245.25 KiB) Viewed 1239 times
pace 6x10 interior finished.png (224.75 KiB) Viewed 1239 times
willfish4fud
Postby willfish4fud » Fri Jul 25, 2014 4:50 pm
Didn't like previous set up for AC. I was going to have it as a fixed mount and though it was only going to stick out about 7-8 inches I decided I wanted it inside a hatch. I built the shelf with brackets and a piece of 3/4" starboard and then added a slider on top (1/2" starboard) that the AC will be attached to. The AC and 1/2" sb will slide in and out of hatch. I put the screws through from the inside so as to leave threaded studs on outside. These will be attachment points for another small shelf to help support weight of AC. It will be removable and will only be added when the CT is set up to camp. When I leave it will be removed (wing nuts) and stored.
pace 6x10 ac sliding shelf.png (235.52 KiB) Viewed 1191 times
willfish4fud
Postby willfish4fud » Fri Jul 25, 2014 4:57 pm
Exterior studs
pace 6x10 ext shelf studs.png (252.46 KiB) Viewed 1191 times
pace 6x10 ext shelf studs 2.png (232.42 KiB) Viewed 1191 times
willfish4fud
Postby AZ_Desert_Rat » Mon Jul 28, 2014 9:07 am
Looking gooood ... :applause:
I like the paneling and the white should help brighten up the interior. I can't wait to see all the final pics ... my wife is bugging me about an AC! I am pushing back on that as I really don't want to go to that much trouble ... generator and limited parking (Hmm, solar sounds good though, maybe a good excuse to add solar). :twisted: That will have to wait, I just added an awning ($$) -- decided to go with a factory model rather than home-grown ... I need to find my camera (still unpacking) and will post those to my gallery soon.
Keep up the good work and keep the pics coming ... 8)
Happy Camping & Building,
John (JC)
The Arizona Desert Rat 6x10' Cargo Conversion
The FunFinder a 19' Toy Hauler
An AZ Desert Transplant
Gallery: gallery/album.php?album_id=3168
AZ_Desert_Rat
Images: 55
Postby willfish4fud » Mon Jul 28, 2014 5:47 pm
AZ_Desert_Rat wrote:Looking gooood ... :applause:
Thanks for the comments. The AC was a pain but here in MS I just have to have it. Pretty sure I could do it faster and cheaper the second time around. Bought solar panels last night. Hope to have them by the end of the week. Id like an awning but I have spent a ton and will probably wait. Look forward to seeing yours...itll probably change my mind. Im doing the bed today and will have more pics tonite. Thanks
willfish4fud
Postby flboy » Mon Jul 28, 2014 7:00 pm
It's looking nice. Are you going to install a sink, Stove and etc.?
Don (Flboy)
https://youtu.be/6_-8cVdWUIA
https://youtu.be/MUcMM86LA2g
flboy
Images: 378
Postby willfish4fud » Mon Jul 28, 2014 7:23 pm
flboy wrote:It's looking nice. Are you going to install a sink, Stove and etc.?
Thanks. No sink or stove. Going to do some form of chuck box with a coleman stove I think
willfish4fud
