Weekender Plywood size
Postby 240zron » Sat May 13, 2006 12:15 am
Hi,
I decided to build the weekender and have a few questions. I have the frame, and floor done. I cut out the sides tonight and have them installed. I'm using 3/4" plywood on the sides, But was wondering what do you think would be the best thickness of wood for the front, top and back?
I was thinking of going with 1/2" and would go thinner if possible.
Thanks,
Take care,
Ron Potts
Member team Genesis USA
240zron
Images: 22
Postby mikeschn » Sat May 13, 2006 1:11 pm
The best thickness is whatever you can put screws into, without splitting the wood. If you can do it with 1/2", go for it. If you find it splitting too much, try something thicker.
The option is to glue some strips of pine to the roof panels, and put your screws into that.
Postby Laredo » Sat May 13, 2006 2:10 pm
Mike,
remember that corner/eave I couldn't build without collapsing it?
The solution is a rabbetted strip of wood that ''slots'' the roof and wall together.
Laredo
Postby 240zron » Sun May 14, 2006 1:35 am
Thanks for the replys.
I was thinking of the pine strips as you described. I'm trying to keep the weight down as much as possible, But don't want t run into problems after is is built. I will be towing it with a Subaru, So I dont want it to heavy, But also want it to hold up.
Take care,
Ron Potts
240zron
Images: 22
Postby JunkMan » Sun May 14, 2006 8:17 am
Ron,
If you are using spars from side to side, you should be able to go with 1/4" or less. I plan to have one sheet of 5MM (just over 1/8") Baltic Birch under my spars (inside, for a cieling), a set of 3/4" x 2" spars with insulation between them, and a sheet of 5MM Baltic Birch on top, with .050 aluminum over that.
See this thread:
http://www.tnttt.com/viewtopic.php?t=3351
Jeff & Odie
Black Hills of South Dakota
JunkMan
Images: 50
Postby weasel » Sun May 14, 2006 8:25 am
I used 5/8 ply, no spliting and worked well.
weasel
Postby 240zron » Mon May 15, 2006 12:42 am
Thanks for the help, I decided to go with the 5/8" plywood. But for now, It's time to get started on the cabinets.
Thanks again,
Take care,
Ron Potts
240zron
Images: 22
