Flatten arc or not?
Flatten arc or not?
Postby Chris C » Sat May 13, 2006 12:14 pm
My design is a modified Cub/Modernaire/Modernistic. (or whatever one wants to call it.) I want to install a Fantastic Vent in the top. To those of you who've been in that same situation, I ask: Do you flatten the arc for 17" to provide a flat mounting surface for the fan, or do you just apply lots of sealer to fill the gap? :thinking: Comments please.
Chris :D
Chris C
Re: Flatten arc or not?
Postby Kevin A » Sat May 13, 2006 12:19 pm
Chris C wrote:My design is a modified Cub/Modernaire/Modernistic. (or whatever one wants to call it.) I want to install a Fantastic Vent in the top. To those of you who've been in that same situation, I ask: Do you flatten the arc for 17" to provide a flat mounting surface for the fan, or do you just apply lots of sealer to fill the gap? :thinking: Comments please.
Chris,
Couldn't you build a shallow wooden frame work that fit in the roof that would provide a flat area for the vent to mount in, without flattening your roof line?
Kevin A
The other guy
Images: 289
Postby Darren » Sat May 13, 2006 12:39 pm
Chris, I'm attempting to do it like Kevin said. Keep the side profile curved and have a flattened area for the vent. You can slightly see the flat areas in the front and rear views.
I'll let you know if it works out alright. :worship:
Darren
the camper formerly known as Victor Star
Images: 161
Postby mikeschn » Sat May 13, 2006 1:07 pm
The Lil Diner has a gentle arc where the roof vent mounts, and it seals up tight. So yea, you can leave your arc as planned.
Postby Ken A Hood » Sat May 13, 2006 1:26 pm
Just wondering if the trim piece from Scott (fantastic Vent) would work. The one for the airstream has a slight curve, going side to side. Could it be turned 90 degrees and used front to back?
Disclaimer: I in no way resemble the avatar shown. Furthermore, I in no way have any affiliation to the Trailer Park Boys and more specifically Bubbles!
Ken A Hood
Images: 42
Postby Chris C » Sat May 13, 2006 3:04 pm
Mike,
If I screw the fan down in the center, (fore to aft) there will be a little over a quarter of an inch gap both fore and aft. :thinking:
Chris :D
Chris C
Postby Chris C » Sat May 13, 2006 3:29 pm
Kevin and Victor,
Looks to me like another place for a leak................in a really bad spot! Just my opinion though. I'll be interested in seeing how well it turns out for you. :thinking: Think I'll stay with just one hole in the roof.
Chris :D
Chris C
Postby asianflava » Sat May 13, 2006 3:45 pm
Chris, mine is exactly what you described. The flat spot on my roof is about 20in. Unless you knew to look for it, you'd never notice.
asianflava
Postby Gage » Sat May 13, 2006 4:10 pm
Yep that's what I was going to say. Just install it and don't worry about it. It will conform.
Have a good day
:thinking:
Now go buy some plywood.
Image Image Image
Gage
Images: 28
Postby Kevin A » Sat May 13, 2006 7:22 pm
Chris C wrote:Kevin and Victor,
Yup, and that's why you won't see a roof vent in my tear. However, you DID ask for advice on how to accomplish the installation and for ideas on keeping the original contour or building a flattened area. I offered a suggestion that apparently wasn't appreciated. Obviously, you're going to have to spend a little time eliminating leaks no matter how you go about installing any roof vent. With your woodworking back ground that task shouldn't be that difficult for you.
Kevin A
The other guy
Images: 289
Postby Arne » Sat May 13, 2006 9:33 pm
Roof vents don't leak. Or, I've never had one leak, nor heard of one leaking.... They have a gasket. Then you put silicone dabs on each screw....
People talk about these things like they are mounted in a submersible and have water under pressure just trying to push in. As far as this topic, I would not bother putting a flat spot in the roof. I would mount the vent at the top of the arc, with a screw on the middle of each side. Then I would cut strips to put under the front and back, of equal height and put in the gaps. On the side gaps, I might bother to put in tapered strips.
There are about 6 screws on each side, or about 20 total. To hold down a 14 x 14" vent. The strips mentioned above would be set in about 1/4 inch, and some type of caulk would be used to fill the gap..... done.
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby Chris C » Sat May 13, 2006 9:37 pm
Oh Kevin, I meant no offense! Honestly. :shake hands: I just don't want to have any more joints in the top than I have to. Sorry if my response came off wrong. Just not sure what to do here. Guess I'll go ahead and provide a flat spot in the curve.
Chris :D
Chris C
Postby madjack » Sat May 13, 2006 10:27 pm
Chris, I think if I were you I would just make it curved and then take one o' them scrapers you are so fond of and scrape a flat spot for the vent to sit/seal to.......
madjack 8)
Postby An Ol Timer » Sat May 13, 2006 10:34 pm
Today my grandson and I were putting the centercoard case into the sailboat that we are building for him and all I could think of was "Boy those guys and their paranoia about leaky roof vents sure wouldn't make boatbuilders." :lol: :lol:
An Ol Timer
Postby Chris C » Sat May 13, 2006 10:35 pm
madjack wrote:Chris, I think if I were you I would just make it curved and then take one o' them scrapers you are so fond of and scrape a flat spot for the vent to sit/seal to.......
madjack 8)
:lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
Chris :D
Chris C
