wtcreaux wrote:Be aware that the AC, though running on 15 amps, draws up to 27 amps for starting (at least mine does for which I bought a 2nd 2k watt generator and buddied it)
bc toys wrote:D/C is easy as A/C you got ground and hot just run 2 wires to every thing green and black or red and black gr for ground and black for hot but if you go black and red the black will be the gr and red will be the hot get a fuze block with a ground bar attached D/C is nice if you are traveling and need to stop for the night and can't run the gen. its nice to be able to turn on a light. I have both A/C and D/C
