Welcome in! I have a 4x8 trailer, meant to be a 4x8 trailer....The problem I had was making it a 4x8 trailer, from a 4x5 (actually 50"x60") trailer. Although my plan was to use a derelict trailer I bought for $50 at a swap-meet (if only to transport a $50 minibike home), and I intended to keep it as light as possible, it and my plans/equipment/costs got way out of hand. I tried to build it sturdy, from good materials, and spent a little at a time, but every change in plan added more plans/equipment/costs (and weight). And then more problems cropped up, making me regret trying to save a buck, and using what I suspected to be true: a frame/axle insufficient for my needs/usage (the original "spindly" axle separated from the frame; I replaced with a heavy-duty 3500lb Dexter) . Hopefully, you can plan one and stick more closely to your plan than did I. My advice (from my experience), spend the big money up front, get known quality parts, follow your plans and don't experiment (I can't help myself from doing that!), and enjoy your build.dperry324 wrote:Hello All! I'm still planning my first build, and I have a trailer question.My trailer needs to be 5 feet wide, in order to use a full-size mattress. I had intended to use the HF 4x8 trailer, but obviously, unaltered, that will not hold my 5' wide trailer....This is my first build, and I'm trying to not make it too spendy. The next alternative I see is to get a 5x8 from Northern Tool, but that adds an extra $150 to the price of the trailer alone
bobhenry wrote:Yes Yes and Yes. You feel like you are outdoors.
Woodbutcher wrote:Unless you camp alone, or are married to a super thin model, the 4 wide is pretty cozy. Most couples prefer a 5 wide, and they are much easier to sell when ypu build the second one.
Woodbutcher wrote:Unless you ... are married to a super thin model...
dperry324 wrote:I fully intend to do a cardboard mockup...
