This is my last build 6x10
Re: This is my last build 6x10
Postby bc toys » Fri Aug 15, 2014 8:18 am
I got my insolation at HD and as far as the wiring ti is above the panels it is tucked up there and will get hid by another piece of trim and I don't recommend you drill into your studs they are only 1'' thick and it will weaken them it you drill a 1/2'' hole or bigger and as far as coming down to the level it is behind the panels and comes out into a wire mold box made for surface mounting you can get them at HD also get the deep one for D/C power or you will have to knock out the back bigger and reset it into your wall about 1/4'' the 2 cords coming down in the front of my trailer are my A/C power that go next to my D/C power on each side of the trailer and plug into a power strip with a trip set at 15 amps. Looks like I'm going to be raisin the bed about 2'' can't get my storage boxes under the bed and don't want to buy more boxes
bc toys
Images: 42
Postby bc toys » Sun Sep 07, 2014 9:24 am
Got floor finished used the decking restoring It went on great took 2 days to get it done will post pics later on today. had to unload everything and put plastic up 2ft on the walls and still got it on walls on a couple of spots but all in all I like how it turned out. got everything moved back in and ready for camping trip in 10 days.
bc toys
Images: 42
