rdraider wrote:...I'll have to fit a stove, built in ice chest (or removable cooler) and maybe a sink. I'm getting one of those eco temp on demand water heaters too. With a flo jet pump. Oh, and an air conditioner. Window unit ac, 5,000 btu....I guess what i'm saying is i need to see how a more vertical galley works out, ergonomically!
OK, mine is not a grasshopper, nano, or weekender, just an overstuffed "Simple". But, it's got a lot of equipment in its' vertical "galley". I built it vertically, 20 inches deep, allowing 76 inches inside the cabin for a twin-size mattress. I chose an angular form as the "simplest" way to create a TTT with limited woodcrafting skills, more conducive to a successful outcome, given my bolt-together background. I intended to put a "kitchen" back there originally, but I chose to go with side-tables for food prep, and only have a water jug and a cooler, and my dual-fuel Coleman gear and fuel (as kitchen stuff) back there. The remainder of the space (20" deep x 48" tall x 46.5" wide = 25.83 cubic feet) is dedicated to power or A/C
- a) 12vdc power connections-hidden,b) 120vac power supplies-2500 watt generator on slide-out turntable w/ extended-run fuel tank! -or- park power thru 12ga extension cord (w/ GFCI & Surge protection), c) 5000 btu A/C exhaust ducting system.
The generator and peripherals, and A/C ducting were my primary focus in constructing the galley. I had a plan to fit them in, regardless. So, the domestic operations of the galley were dismissed. The A/C was to be able to run with the hatch closed and locked up for the night (so no mischief would occur), and the generator was there to supply power in boondocking situations where no park power exists. To do it over again, the generator would've been in a box on the tongue, and the A/C ducting would've been routed straight back (thru a small, louvered hatch, inset in the main hatch)
- galley, A-C ducting, water, fuel, generator layout.jpg (148.27 KiB) Viewed 1423 times
- upper galley details.jpg (94.23 KiB) Viewed 1423 times
Remove the generator and fuel supplies, re-route the A/C exhaust, and there's ample room for counter space, stove, and heated water supplies. But, beware of possible rearward weight bias-mine was substantial!
