I realized this morning that I'd need to drill the hatch for the license plate bracket and light, so I did that first thing, along with drilling the other wall for the side and porch light. Here are the lights from when I tested if the holes were big enough (the side lights needed a 3/4" diameter, 3/8" deep recess due to their wiring design), they're not screwed in thus why the red one isn't in line with the yellow one. You can see where I had to place the yellow marker to get it inside the forward storage compartment without sticking past the front of the trailer, unfortunately that also puts it in a position to be smacked by the door if it swings freely. I'll have to put restraining straps on the doors so they can only open ~135 degrees.
- 20140824 lights small.jpg (144.74 KiB) Viewed 1810 times
Then I spent the next 5 hours putting several coats of epoxy on the trailer body, the hatch, the tongue box and the galley seal area. It looks like I'll be able to sand later this week and primer/paint this upcoming weekend. The end is in sight.
I did discover that I'm one short on wiring holes through the roof spars, so I'll have to improvise and run some of the light wires as multiple hots to a single ground (shouldn't be a problem since they're all LED, and it will be combinations not likely to be paired such as the porch light and the reading light).
The upcoming big challenges: Building the tongue box lid, cutting the aluminum angle for the galley hatch latches (4" angle, 3/16" thick, good thing I'm visiting my parents for labor day and can use the milling machine or my hacksaw would be getting quite a work-out
) and figuring out how I want to run the latches across the AC door's t-molding.
