Least odor toilet?
Least odor toilet?
Postby khigh » Mon Sep 01, 2014 1:09 pm
Welp - my trailer is constructed and I've got an awful lot of the planned stuff in hand to start building, but I keep running into a wall with toilets. It's kind of a middle ground for me. I've never experienced. I've always either been "go in the woods" or "full blown septic system".
The plan is when I'm full blown set up to take it outside and put it in a shower enclosure kind of thing, but bring it in at night for any random peeing. Then I anticipate some stealth overnight trips where anything could happen in it.
I think I'm not understanding the technology. There are two major kinds (three if you count $$$$ Composting) once you get past going in a bucket or the little stand with a bag under it.
The water flush kind and the chemical kind. Is that a fair "narrowing it down"?
Any huge advantages one to the other?
Thanks for looking.
khigh
Re: Least odor toilet?
Postby jwhite » Mon Sep 01, 2014 1:46 pm
I did like most and bought the portable toilet that you can buy online, these are a great invention but the problem is empting them, what I did was put in a pvc drain pipe that I can open a empty it from the out side.
863438634486341
When I get home I take a water hose inside and flush out really good and refill the toilet with water.
I also built a box out of wood and put in a regular toilet seat.
also what really helps for odors, I bought those toilet cakes that hang over the side and they really are strong smelling.
that's the best thing I have found.
jwhite
Images: 46
Postby khigh » Mon Sep 01, 2014 3:15 pm
I think this is a case of researching something til I'm more confused than when I started. Now I think the term chemical toilet is used interchangeably with the portable RV style that "flush"? That you fill it with water and there's a waste tank, but then you put some chemical in it, too.
So short version - any reason I wouldn't get this Camco? http://www.amazon.com/Camco-41541-Porta ... ble+toilet
I'd spend up to about $200 on one if the extra is buying any additional odor control. Much past $200 and I'll just have to bring some candles.
khigh
Least odor toilet?
Postby abqlloyd » Mon Sep 01, 2014 3:37 pm
Porta-potty has an attached black tank at the bottom. The top is separated and the black water is poured down the sewer or toilet.
RV toilets drain to a separate black tank which is then drained via a hose to an RV waste drain. My neighbor had a drain installed at home for a ~$200 so he can just drain when he gets home.
There are also systems that use a larger black tank on wheels in conjunction with a traditional RV toilet.
All of them use a chemical in the holding tank to break down waste and control odor.
abqlloyd
Postby abqlloyd » Mon Sep 01, 2014 3:40 pm
The Thetford are very popular. We have the 365 and it works fine for the girls. It was in the truck camper and would last a weekend.
abqlloyd
Postby AZKayaker » Mon Sep 01, 2014 5:30 pm
I also have a Thetford. Once I found a decent deodorant, I was hooked. No more Luggable Loo's for me.
See my 5x9 SquareDrop CT conversion build, trip pics and more
gallery/album.php?album_id=3552
AZKayaker
Images: 38
Postby Rainier70 » Mon Sep 01, 2014 8:45 pm
I have a Thetford for the grandkids etc. Seems pretty airtight. I haven't had it very long. What are you using for deodorant?
Rainier70
Images: 244
Postby abqlloyd » Mon Sep 01, 2014 9:00 pm
We use the biodegradable Thetford stuff and it works as good as the really caustic blue stuff.
abqlloyd
Postby AZKayaker » Mon Sep 01, 2014 10:26 pm
I use Thetford Campa Chem Natural.
AZKayaker
Images: 38
Postby khigh » Tue Sep 02, 2014 1:14 pm
Thanks for the replies all.
Sounds like Tetford is a good bet.
I cheaped out and went the Camco for now at least for my shakedown trip.
If I'm not thrilled I'll return it, (I'm kidding, but can you imagine? "Sorry - didn't have time to empty the dump tank to make the return window")
Seriously, though - If I'm not thrilled I'll try something else and put that one with the emergency supplies.
khigh
Postby AZKayaker » Wed Sep 03, 2014 7:29 am
Sounds good. The only thing that I don't like about my Thetford, is that it's just 2.6 gallon capacity. My next toilet will be at least 5 gallons.
AZKayaker
Images: 38
Postby Jdhiker » Wed Sep 03, 2014 10:40 am
Thetford curve is what we have. We use it in a privy tent... It's almost regular toilet height...curved front for the " gentleman" and holds 5 gal worth of "stuff". It's electric flush and was odor free. Great, I bought on Amazon for 129.00
Jim & Charlene
Belchertown MA.
Working on Benny the "Shasta Mini" !! to be pulled behind 2012 Honda CRV
Blog, http://www.jdhiker.wordpress.com
other campers I'm working on
64 Beeline Wasp
66 Shasta compact
and out family Standee is
26' 2012 Keystone Summerland towed with a 2003 GMC 2500HD Crew CAb
Jdhiker
