by working on it » Fri Aug 15, 2014 10:29 am
ENVY !!! The predicted high temperature at Bon Echo Provincial Park is 70 degrees on Saturday, whereas the predicted high at one of our nearby State Parks (Cleburne, site of my next trip...thankfully not this month!) is 102 degrees. Even with A/C, that's a little warmer than I would like to camp in. But, once I really get into this camping thing (slow to resume after 35 years), then I'll take whatever Mother Nature throws at me. But, with no insulation, I doubt I would camp in Ontario in the winter. Enjoy your good weather!
2013 HHRv "squareback/squaredrop", rugged, 4x8 TTT, 2225 lbs- *3500 lb Dexter EZ-Lube braked axle, 3000 lb.springs, active-progressive bumpstop suspension
- *27 x 8.5-14LT AT tires (x 3) *Weight Distribution system for single-beam tongue
- *100% LED's & GFCI outlets, 3x fans, AM/FM/CD/Aux. *A/C & heat, Optima AGM, inverter & charger(s)
- *extended-run, on-board, 2500w generator *Coleman dual-fuel stove & lantern, Ikea grill, vintage skillet
- *zinc/stainless front & side racks *98"L x 6" diameter rod & reel carrier tube on roof
