Noob wants 12x6 CT with ramp door
Re: Noob wants 12x6 CT with ramp door
Postby chiefb711 » Sat Sep 06, 2014 7:24 pm
sbshaver wrote:Thanks, yes Uhauls seem a bit wider and yes, a 7x12 seems way roomier than 6x12. but oh the price...the horror... :cry:
7x12 is going to pull a lot different than a 6x12 though, especially behind a minivan. Make sure whatever you get your vehicle is equipped to haul your final product. I went with an upgraded 5000# axle because I know the weight of the trailer dry is going to be close to 3000, which is too close for me. It's all about what you plan to do with it and how comfortable you are towing the trailer. Good luck in whatever you decide to do, this website will surely help you determine your want list. The guys on here are more than willing to help you with ideas.
Ryan
chiefb711
Images: 62
Postby sbshaver » Sat Sep 06, 2014 8:14 pm
Couple more questions. Looking at the LOOK trailers. All 6x12. They''re a little different from each other.
1) is an RV door worth paying extra for compared to a cargo door? Pros and cons?
2) Is a factory roof vent worth paying for? Or will I end up upgrading the vent anyway so might as well put a vent in after purchase?
3) Most of the Looks have a smooth thin looking plywood on walls and ceiling. It's attractive and looks like veneer almost. But one of the Looks has what looks like OSB particle board on the walls and ceiling -- never a big lover of particle board. Is one preferred over the other? I plan to insulate it. For sure that veneer is better looking.
sbshaver
Postby David_L6 » Sat Sep 06, 2014 8:33 pm
sbshaver wrote:Couple more questions. Looking at the LOOK trailers. All 6x12. They''re a little different from each other.
If you're talking about an "outside" door and a screen door inside of it, I'd say YES. I wish that both of my trailers had come with a door set up similar to a travel trailer (door with window and a screen door).
sbshaver wrote: 2) Is a factory roof vent worth paying for? Or will I end up upgrading the vent anyway so might as well put a vent in after purchase?
I'd say yes. Wouldn't be fun to add later if you decided that you wanted one. They have a frame work welded into the frame. It's not just a hole through the roof with the vent in it.
sbshaver wrote: 3) Most of the Looks have a smooth thin looking plywood on walls and ceiling. It's attractive and looks like veneer almost. But one of the Looks has what looks like OSB particle board on the walls and ceiling -- never a big lover of particle board. Is one preferred over the other? I plan to insulate it. For sure that veneer is better looking.
One of my trailers came with plywood and the other came with that other stuff (whatever it is). I prefer plywood... No reason, but I prefer plywood.
David_L6
Images: 16
Postby sbshaver » Sat Sep 06, 2014 8:56 pm
I think by RV door they mean openable from both sides. and no clamp assembly to squeeze door shut. pic.
sbshaver
Postby sbshaver » Mon Sep 08, 2014 3:54 pm
This is the CTC that got me interested. And it still is my favorite because of the sheer simplicity. Gotta love da Joysee accent.
btw, are cargo ramp doors openable from the INSIDE provided the exterior clamping hardware is not engaged?
https://www.youtube.com/watch?v=k12iJpAv4DE :thumbsup:
sbshaver
Postby bc toys » Tue Sep 09, 2014 7:07 am
well I have a 6x10 V nose LOOK and I love it it has the RV door changed after purchased wish I had ordered it with RV door it has vent on top and it came with it the inside wood is 1/4'' pressed wood has barn doors in the back didn't want ramp or the single big door I've wired it trimmed it and finished the flooring with deck seal restore and I like how it turned out hope this helps you
bc toys
Images: 42
Postby sbshaver » Tue Sep 23, 2014 5:48 pm
Here is my new Look. It's tall!
sbshaver
Postby sbshaver » Sat Nov 08, 2014 4:13 am
Update: haven't done much. Varnished the plywood floor and ramp a few times. Bubbles everywhere. Got a marine 12v and box. Today got really ambitious and put a thru hull fitting in so I can run a power cord through to the inside of the CT. This of course meant I popped the cherry and actually cut a 5" hole in the skin. Heaven forbid! I used aluminum snips with the angled noses. It's like cutting through butter. Used a electric jig saw to cut the plywood panel. I'm worse than I remembered at carpentry, but nothing a bunch of silicon and bondo can't fill in right guys!
sbshaver
